Old 01-17-2011, 04:47 PM   #1
New thermostat for heat
I think the house is wired wrong how do i tell which wires on the unit matches the wires on the thermostat
danesdad is offline   Reply With Quote
Old 01-17-2011, 05:10 PM   #2
If you think there's splices and color changes the only sure way to tell is disconnect the wires at each end then tie two together and check for continuity.
Old 01-17-2011, 07:24 PM   #3
Average Joe/ex-Navy IC3
gregzoll's Avatar
Go look at the circuit board or where the wires are connected in the furnace, then compare colors & terminals on the thermostat.
Honeywell thermostat wiring wcb22 HVAC 5 01-10-2011 06:54 AM
Carrier Edge Thermostat Installation Issue ptalar HVAC 1 07-13-2010 06:40 PM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-10-2010 12:58 AM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 08:48 PM
Thermostat from Manual to Digital trinamillersmit HVAC 5 07-02-2009 10:21 AM
