Old 12-06-2007, 12:44 PM   #1
New Thermostat and Furnace Not Working Right
Brand new house, just moved in. New thermostat, new furnace, etc.
No matter what I set heat at, the heat will come on when it is not supposed to. Thermostat will say set to 71, room 77 and heat will turn on and off maintaining a different heat setting all the way up to turning on at 79 or higher.
Even worse, heat turns on when thermostat system switch is set to off (fan set to auto). I had everything off, was standing under furnace (in attic) and by thermostat and it turned on and off like it was set to something.
Our house keeps going to 80 degrees and for most winter locations that is nice, but not in Vegas.
Left a message with the builder, but wanted to know everyones take on the cause of this.
Vegas Resident is offline   Reply With Quote
Old 12-06-2007, 07:42 PM   #2
no, but that sounds crazy! I already have thought a few off the wall ideas, but this one really needs looked at.. hope the builder takes care of you!
sixty7flh is offline   Reply With Quote
Oil Furnace - Swapping out to Programmable Thermostat slappy HVAC 2 12-05-2007 04:57 PM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 11:17 PM
Tie-in of a Coleman electric furnace nilo HVAC 9 01-03-2007 04:45 PM
Furnace stops working once a day - help Da_Bears HVAC 2 01-26-2006 02:19 PM
