New Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 12-19-2010, 04:43 PM   #1
Rewards Points: 12
new thermostat
I just installed a wood stove in our basement last week. I figured it was time to take a dent out of heating here solely with the propane fired Lennox elite series furnace.
The newer furnace was wired up with the buildings original 2 wire thermostat.
I would like to install a mechanical Honeywell 'stat so I may run the blower continuosly. That way, the furnace blower will help circulate the heat throughout the house better. (even though the stove is not attached to the plenum), at least the air will be moving it better out of the basement!
I see the terminal bus where the 2 wire 'stat hooks up has 6 terminals. I imagine those are for various thermostat configurations.
Can anyone tell me which one's to use for the 'fan on' continously?
and before I head off to the supplier, how many conductor wire will this take? 4?
Maybe there is a way to 'jumper' it, with a switch at the furnace itself, thereby foregoing the need for a new 'stat?
Thanks!
Bob
rancherman is offline   Reply With Quote
Old 12-19-2010, 05:11 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,166
Yep. Run a 2 wire 18/2 LVT wire (buy off the roll they cut it for you) from HDepot and a light switch in a 2x4 metal switchbox from the Depot and mount it on the return duct with a cover. Hookup to R and G on the circuit board and Bob's yer Uncle.
The Following User Says Thank You to yuri For This Useful Post:
rancherman (12-19-2010)
Old 12-19-2010, 07:13 PM   #3
JJboy's Avatar
Fan on: R - g
JJboy is offline   Reply With Quote
The Following User Says Thank You to JJboy For This Useful Post:
Old 12-19-2010, 10:43 PM   #4
Rewards Points: 12
Thanks! I appreciate the info! Now I just wish I cut more wood before the snow got deep.....
Merry Christmas!!
Bob
Old 12-19-2010, 11:05 PM   #5
Here's another option for you. Get a second thermostat and set it a degree or two below the other. Wire R and W on the second thermostat to r and g on the furnace. New thermostat will bring on the fan when the room cools off and shut it off when it's warm enough. If the wood burner goes out then the propane will come on. Got yourself a fancy pants two stage system that way for the price of a thermostat
The Following User Says Thank You to Marty S. For This Useful Post:
rancherman (12-20-2010)
Old 12-20-2010, 11:07 AM   #6
Rewards Points: 12
good idea! I think I will try the jumper first just to see if the heat is moved around better, then go with the second 'stat' I like that idea!
Thanks Marty
Bob
Carrier Edge Thermostat Installation Issue ptalar HVAC 1 07-13-2010 06:40 PM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-10-2010 12:58 AM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 08:48 PM
Two Wire 24V Thermostat to Digital Thermostat on Pellet Stove jrodtaclet Electrical 4 09-15-2009 06:37 PM
Thermostat from Manual to Digital trinamillersmit HVAC 5 07-02-2009 10:21 AM
