#1 |
New thermostat
Just purchased a new honeywell ct87k thermostat. Have old floor furnace. On old thermostat had two unmarked wires (a black and red). I connected the red to R and black to W, but it did not work. So then I connected the black to the Y and the heater kicked in. Problem now is it is always on, cannot get it to shut off, even when I move the setting all the way down. Is there something i am doing wrong or is the thermostat defective??
#2 |
New thermostat
If you check continuity between R and W with the switch on heat and it doesn't behave right, you got a bad tstat. Same goes for R and Y in cooling mode.
#3 |
New thermostat
The Y is for cooling. I don't think it's an option on floor furnaces. I think the problem is the new thermostat is a 24 volt thermostat. Typically floor furnaces have millivolt systems which is very low dc voltage. It won't power a 24v thermostat. They do make digital thermostats that are compatible with millivolt systems. Will specify this on the package, usually powered by batteries.
| Display Modes | |
| Thermostat VS Ceiling fan | MrShadetree0222 | HVAC | 38 | 01-23-2010 04:29 AM |
| Wiring help - Honeywell Thermostat w/ Carrier Heat Pump | Tom Williams | HVAC | 7 | 09-14-2008 08:40 AM |
| Oil Furnace - Swapping out to Programmable Thermostat | slappy | HVAC | 2 | 12-05-2007 04:57 PM |
