#1 |
New Thermostat - 24V from furnance
I would like to install a new thermostat (wi-fi) which requires external power.
I found 24V terminals from the furnance, however, they are already in used. (One connect to motor, I am not sure about the other). Can I hook this new thermostat on to it? |
#2 |
New Thermostat - 24V from furnance ...they mean 24Vs constant on the subbase from the furnace you shold alraedy have R at there,so you need the C side of the transformer in the furnace so you read 24V with just the subbace wired or before connecting it to the base...stay away from the motor side and the 115Vs within the furnace...reason you need a constant 24Vs is the draw on the new stat solid state within...if you just used the R without a C pulled up there the stat would light up but have no action |
| The Following User Says Thank You to biggles For This Useful Post: | thone (07-27-2011) |
| Display Modes | |
| Thermostat issues on old furnace - questions before I replace thermostat. | Calab | HVAC | 11 | 02-18-2012 09:43 AM |
| Need help replacing an OLD General Controls Thermostat | ohman | HVAC | 3 | 06-08-2011 06:35 PM |
| weathertron Mecury Thermostat | VickiL | HVAC | 4 | 02-06-2011 05:32 PM |
| Thermostat issues | rathipon | HVAC | 4 | 01-29-2011 12:46 PM |
| Carrier Edge Thermostat Installation Issue | ptalar | HVAC | 1 | 07-13-2010 06:40 PM |
