New Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 12-06-2012, 06:06 AM   #1
New Thermostat
I have a 3200SqFt home with (2) A/C units. I want to try to find a thermostat that I don't have to manually switch from A/C to Heat.
We are in North Texas and some days it's still 70 in the morning
and others 40! The wife is tired of waking up to a cold house
due to forgetting to switch from A/C to heat!
I did google this but didn't find somthing that I could install, found items that you could control from an IPhone and stuff like that, but all were
expensive?
Thanks!
pinkfloyd43 is offline   Reply With Quote
Old 12-06-2012, 06:17 AM   #2
PoleCat's Avatar
Rewards Points: 1,652
I worked in a building that had automatic change over thermostats in all the public areas. They were fighting each other 24/7. We changed them all to manual and the units barely ever ran after that. Is one stat to control both units an option?
PoleCat is offline   Reply With Quote
Old 12-06-2012, 07:48 AM   #3
Rewards Points: 6,652
I think you would be better with a system, that would allow you to have a remote sensor for system 1 & system 2 in those zones, so if say system 1 kicks on, system 2 does not kick on, vice-versa. With auto, they will be fighting with each other.
Now of course, there are management/control systems that will do the same thing. They are just basically a computer controller that watches all zones on all systems, but you are talking $$$.
Old 12-06-2012, 08:20 AM   #4
Rewards Points: 1,192
Sounds like you need more insulation if your house gets cold that quickly.
bobelectric is offline   Reply With Quote
Old 12-06-2012, 08:25 AM   #5
Willing to listen
Rewards Points: 223
Pinkfloyd many thermostat manufacturers have mid to higher end digital models with the "Auto Changeover" feature you are looking for. White Rodgers 1F80-0471 is just one example.
Done That is offline   Reply With Quote
The Following User Says Thank You to Done That For This Useful Post:
pinkfloyd43 (12-06-2012)
Old 12-06-2012, 09:34 AM   #6
SuperJETT's Avatar
Rewards Points: 156
$100 for 3M Filtrete CT50, has auto and is internet enabled as well.
SuperJETT is offline   Reply With Quote
Old 12-06-2012, 09:42 AM   #7
Willing to listen
Rewards Points: 223
If you go the internet thermostat route make sure you have a "C" or common wire at the existing stat(s) or are able to run one. Many homes don't have this and are running battery power tstats....just FYI.
Old 12-06-2012, 10:54 AM   #8
That is not a viable option for them, due to they really need a system that monitors both zones, and depending on the temp in either zone, would either tell one unit or both to kick on if needed, while in auto mode.
Old 12-06-2012, 10:58 AM   #9
SuperJETT's Avatar
Rewards Points: 156
I don't see where that was requested as a feature from the OP, just wanting Auto between heat/ac.
Old 12-06-2012, 12:04 PM   #10
Go back and read post 2. It states what will happen when you have two systems running on auto. That means that you have to use some type of controller or remote sensor in the zone, to keep the fighting from happening.
Only thing a Internet connected thermostat will allow, is remote changes or changing from their seat if they have a laptop/netbook/tablet or iPhone/smartphone.
Old 12-06-2012, 12:08 PM   #11
SuperJETT's Avatar
Rewards Points: 156
Post 2 is not the OP. I'm just trying to help answer the question asked by the OP. His problem is his thermostats don't have Auto mode, not that they are fighting with each other.
Old 12-06-2012, 01:16 PM   #12
JJboy's Avatar
He still can hire a Mexican woman to walk on the cold house to setup the thermostat for his wife....LOL
Sent from my iPhone using DIY Forum
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 08:43 AM
Thermostat for electric baseboard wiring help needed vae_victis HVAC 10 01-05-2012 10:53 AM
weathertron Mecury Thermostat VickiL HVAC 4 02-06-2011 04:32 PM
Thermostat issues rathipon HVAC 4 01-29-2011 11:46 AM
Carrier Edge Thermostat Installation Issue ptalar HVAC 1 07-13-2010 05:40 PM
