New Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 04-03-2011, 05:40 PM   #1
Unhappy
New Thermostat
I have a heat pump on the outside and a unit under the house, which I assume is called a split system (help me)... We have the antique looking thermostat installed now. (all manual) I purchased a new Hunter touch screen 44905. I removed my old and noted the wires. I installed the new one and I can't get the system to turn on. The old is wired as below, I have a black wire that never was hooked up, so I assume It has no purpose.
Y=yellow G=Green R=Red O=Orange
W2=White
E=Brown C=Light Blue
The new thermostat has the following, The left side is for Heat Pump and right for Conventional. Thanks for any info and help. These things have made me feel like a big dumb A$$...
R Rh
Y Rc
G Y
- G
L W
O -
B -
A/E -
Y2 W2
C Y2
- C
- A
- W3
01fordeb is offline   Reply With Quote
Old 04-03-2011, 06:38 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
R Rh = RED
Y Rc = YELLOW
G Y = GREEN
- G
L W
O - = ORANGE
B -
A/E - = WHITE AND BROWN
Y2 W2
C Y2 = LIGHT BLUE
- C
- A
- W3
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 04-04-2011, 07:32 AM   #3
Thanks for the info, I have 1 more question. The brown, and green are connected at the thermostat and travel to the air handler, but out at the heat pump, these wires are not connected at all. Do these wires just function on the handler.
Old 04-04-2011, 04:26 PM   #4
AKA HVACTECHFW
no, they have no function on the outdoor unit. Green is indoor blower, and brown is second stage aux heat.
IT IS WHAT IT IS
The Following User Says Thank You to hvactech126 For This Useful Post:
01fordeb (04-05-2011)
Old 04-05-2011, 06:51 AM   #5
Thanks, I found that the fuse on the handler was blown during the install of the new thermostat. I have the new up and running. Thanks for the help.
Tags
cooling , heating , hvac , thermostat
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 08:43 AM
weathertron Mecury Thermostat VickiL HVAC 4 02-06-2011 04:32 PM
Thermostat issues rathipon HVAC 4 01-29-2011 11:46 AM
Carrier Edge Thermostat Installation Issue ptalar HVAC 1 07-13-2010 05:40 PM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-09-2010 11:58 PM
