New T- Stat Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 01-21-2012, 08:26 PM   #1
new t- stat problem
Installed a new T-stat and when system is on in heat mode, AC condenser fan is also running. Unit is only in heat mode not cooling. Ambient temp outside is 10 deg F. Never noticed condenser running in winter before I changed t-stat.
jberard is offline   Reply With Quote
Old 01-21-2012, 08:34 PM   #2
MarginallyQualified
Rewards Points: 2,464
you crossed wires.
go read the instructions again.
for heat the colors that matter are white red and green
Old 01-21-2012, 08:40 PM   #3
I'm Your Huckleberry
Rewards Points: 2,270
The white wire which is included with the bundle of four or five wires is the heating wire, most likely.
Is this a heat pump and can you take some pics of the wiring?
Thanks.
Doc Holliday is offline   Reply With Quote
Old 01-22-2012, 01:18 AM   #4
REP
If you have a jumper between RC and RH then you have to make sure you have the heat-cool-off switch set to heat.
Also it could be bare wires touching each other.I seen way too many stats wired where they have peeled the insulation off too far and when you tighten the stat to the base the wires touch.
If it was working before it should work with a new stat.
REP is offline   Reply With Quote
Old 01-22-2012, 02:55 AM   #5
biggles's Avatar
shut that disconnect OFF outside or knock the condenser breaker down your short cycling the condenser/compressor with it being 10F outside....check down on the furnace for color/lettering IDs from the stat wire drop
Don't understand this breaker tripping problem majesticjess Electrical 10 03-05-2010 07:42 PM
flame sensor problem junkcollector HVAC 1 12-09-2009 09:19 AM
Grout peeling out from shower floor tiles. What's the problem? hellstorm Flooring 6 10-21-2009 10:15 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 07:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
