New Stat Wiring Help - HVAC - DIY Chatroom Home Improvement Forum
Old 05-05-2012, 04:57 PM   #1
Rewards Points: 16
new stat wiring help
Hi folks, I was hoping that someone could help me figure out some issues with a new stat I just bought.
I just got a White-Rodgers 1F85RF-275 with a remote sensor.
I have a gas fired furnace in the basement, single stage by the looks of it.
The wires at the furnace are the red connected to the R terminal and the white connected to the W terminal.
The stat terminals are numerous and most aren't relevant to my setup, I have R/C/Y1/Y2/W2/E-W1/G/O/B/L.
According to the manual,which is not too clear, the red goes to the R at the stat(the hot) the white goes to E-W1(1st stage heat).
Does this sound right?
The display is dim leading me to believe that I'm not getting 24VAC at the hot. The manual said something about adding a resistor to sort that out.
When I get the stat to call for heat the display went blank.
Any ideas as to why it would do that? Am I doing something wrong here?
Please help guys, thanks.
PB
chongololo is offline   Reply With Quote
Old 05-05-2012, 05:30 PM   #2
An old Tradesmen
Rewards Points: 7,344
Do you have the power switch in the PS position for power stealing.
Old 05-05-2012, 05:40 PM   #3
Rewards Points: 16
yes, the switch is in the PS position. I might add the resistors and see if that helps.
Old 05-05-2012, 06:03 PM   #4
An old Tradesmen
You will need if the switch is in the PS position and not working.
You know that that thermostat has been obsoleted already.
Old 05-05-2012, 06:25 PM   #5
Rewards Points: 16
I have the resistors in place and the display is bright now.
I knew that thermostat has been replaced by the 285 but this was on sale and suits my needs.
Backyard wiring questions MikeInDetroit Electrical 1 11-02-2011 09:46 AM
Landscape wiring question: GFCI and Breaker Amp MikeInDetroit Electrical 0 11-02-2011 09:43 AM
Old wiring to new wiring Acworld34 Electrical 3 07-11-2011 10:00 AM
Concrobium and knob and tube wiring WillK Electrical 13 02-28-2011 12:17 PM
Knob & Tube wiring - How concerned should we be? hotdiggitydog Electrical 6 04-11-2006 07:52 PM
