New To The Site And Need Some Help With Roughin. - HVAC - DIY Chatroom Home Improvement Forum
Old 05-26-2011, 09:17 PM   #1
New to the site and need some help with roughin.
First let me say what a cool site! So here's what I'm working with, I'm remodeling our Living Room and I'm adding an extreme exhaust system (my wife is letting me make a smokers room in our living room it has the ability to be closed off.) So I was thinking of installing two vents in the ceiling feeding down through the wall and into the crawl space and connect to an inline fan, then out of the house. The question, 3 out of the 4 walls are load bearing and the fourth has cold air returns and french doors so not alot of real estate there. How do I run a duct through the top plate and into the ceiling without compromising the structure, I know other trades just cut through the plate and I'm a bit leery. Any help would be great!!!
truman0501 is offline   Reply With Quote
Old 05-26-2011, 09:41 PM   #2
Missouri Bound's Avatar
Can you place the vents high on the wall instead of the ceiling? And I do have another thought you may consider. There electronic air cleaners which work very well to eliminate smoke and other odors. They are often used in bars and if sized correctly they do the job quite well. But they generally require an exhaust vent installed on an exterior door. There are some that clean the air and recycle it back into the room but I doubt they are as efficient in cleaning the air as one that would exhaust the air.
Old 05-28-2011, 02:17 PM   #3
I'm not sure how that would affect the performance.
Old 05-28-2011, 02:39 PM   #4
Rewards Points: 292
What is the purpose of 2 vents: intake and exhaust, as in fresh air is sucked into the room from the crawl space, allowed to mix with room air, then sucked out of room to crawl space?
veesubotee is offline   Reply With Quote
Old 05-28-2011, 09:14 PM   #5
The two vents are for exhaust to the outside through the crawl space.
Old 05-28-2011, 09:15 PM   #6
Why not just install an odor/smoke eater it will be a lot cheaper and easier.
Artco is offline   Reply With Quote
Old 05-28-2011, 09:38 PM   #7
The cheapest and easiest thing would be to quit smoking.
Old 05-28-2011, 09:49 PM   #8
30 year tech
hvac122's Avatar
Apparently you never smoked
hvac122 is offline   Reply With Quote
Old 05-28-2011, 09:55 PM   #9
Actually I had. For about 10 years, but that was 20 years ago. I"m not about to preach about it to anyone. I just got tired of everything I own smelling like an ashtray. But it would be cheaper.
Old 05-29-2011, 10:24 AM   #10
30 year tech
hvac122's Avatar
Definatly cheaper but not nessairly easier.
Old 05-29-2011, 12:19 PM   #11
Rewards Points: 292
How large of a fan do you intend to use? Have you considered makeup air?
V
Old 05-29-2011, 02:11 PM   #12
hvac....I'll bet you are not surprised that I hear that all the time. LOL
Old 06-07-2011, 09:13 PM   #13
I was thinking of using a 400+ cfm inline. As far as the make up air is concerned I wasn't sure about how to handle that i was going to be adding a makeup air on my furnace. I was also planning on using this in addition to the system http://www.rgfairpurification.com/solutions.html#reme.
