New Rheem Condenser RPQL-024JEZ Problems - HVAC - DIY Chatroom Home Improvement Forum
Old 06-12-2010, 09:26 PM   #1
I hope someone can help. I had two new Rheem heat pump unit intalled two months ago and now one is shutting down during the hotest time of the day. I checked the condenser unit and found the 7-segment LED display diagnostic code L23, this code refers to a High Pressure Control lockout.
Does any one know what could be causing a new system to do this? by any chance could a undersize liquid line cause this fault. the reason I ask this is that the contractor did not change the line servicing the old unit (in wall) he solder the new bigger diameter line to the existing one.
attached are several pictures of the installation perhaps a trainned eye could detect some error.
The indoor Air Handler is Rheem model - HM2417JA - 24,000 BTU/7.0 kw. Indoor CFM 800.
Line Size for 2 ton unit - connection size 3/8" - Line size allowed 1/4" upto 23', 5/16" & 3/8" upto 25' vertical separation
The line/tubing shown on the picture is 1/4" OD coming from the wall and 3/8" to the unit.
Question what will happend if their is bend on the line would this restrict the capacity of the fluid to the unit? and cause the High pressure shut down?
Regards
Attachment 21572
Last edited by gxsalas; 06-13-2010 at 01:50 PM. Reason: additional Line size info.
gxsalas is offline   Reply With Quote
Old 06-12-2010, 10:03 PM   #2
An old Tradesmen
Rewards Points: 6,116
What size is the smaller line.
And what is the model number of the new indoor coil.
The Following User Says Thank You to beenthere For This Useful Post:
gxsalas (06-12-2010)
Old 06-12-2010, 10:09 PM   #3
What's the OD of the old liquid line? Looks like 1/4" and that will not work with 410A.
The Following User Says Thank You to Marty S. For This Useful Post:
Old 06-12-2010, 10:13 PM   #4
An old Tradesmen
I think Rheem allows 1/4" on their 2 ton. 5/16 on their 2.5 ton.
But it could be that it needs min 5/16" on the 2 ton. Can't remember anymore.
Old 06-13-2010, 10:38 AM   #5
Mad Scientist
Not really related to the problem at hand, but what's tapped off your A/C disconnect? That conduit coming out of the right-hand side. The hot is double-tapped on the A/C breaker, and the neutral and ground are both connected to the ground bar
McSteve is offline   Reply With Quote
The Following User Says Thank You to McSteve For This Useful Post:
gxsalas (06-13-2010)
Old 06-13-2010, 12:05 PM   #6
Probably overcharged. Have the installer change the breaker to a 30 amp instead of that 40 amp while he's there and fix the wiring problem McSteve pointed out.
Old 06-13-2010, 01:43 PM   #7
Previous owner riged the water sofner to the A/C disconnect, it is out now I am in the process of connecting a sub-panel to provide a proper connection for the water sofner and the additional lighting and recepticals I am in the process of adding.
Thank you very much for the advise.
I changed the braker to a 30 A switchable at the cut off box to protect the unit.
Thanks you
Old 06-13-2010, 01:59 PM   #8
Hvac Pro
yuri's Avatar
Rewards Points: 1,130
If you are in Florida and get brownouts/lightning storms etc you may want to investigate a whole home surge protector. A major brand like Siemens or Square D is worth looking into. I am not sure they work 100% but some research on the web may help and advice from electricians.
The Following User Says Thank You to yuri For This Useful Post:
Old 06-13-2010, 09:42 PM   #9
I have a whole home surge protector installed by Progress Energy (at the meter). The unit will shut down mid-day and will not restart untill late afternoon about 6:00 PM, by that time bedroom area has reached 82 degrees.
I changed the cut off switch to a fusable 30A, no luck the braker did not trip. The unit just won't start.
Old 06-14-2010, 07:24 PM   #10
Looking at Rheem's Heat pump refrigerant line size info for the RPQL 2 ton. The maximum "Total Equivalent Length" for 1/4 inch line is 25 feet. That means you have to take into account elbows and other restrictions in the line. An elbow might be considered the equivalent of 2 feet of line. Not sure what it is. But if your line set is over 25 feet you need to go larger. 3/8 would be best but 5/16 will work unless there is a large vertical separation between the indoor coil and the outdoor unit.
Mike in Arkansas is offline   Reply With Quote
Old 08-10-2010, 11:21 PM   #11
gxsalas, I am having this same exact problem with the same Rheem unit, RPQL024JEZ. I also have 1/4'' in the house running out to the unit. I'm getting the L23 code as well.
Was wondering if you had found the cause of your problem. Really appreciate your time and everyone's previous replies to this thread.
rheem123 is offline   Reply With Quote
Old 07-21-2011, 08:32 PM   #12
L23 fault code
I too am getting L23, very hot day, fan not turning.
curious what actual outer dimension is on 1/4 line to verify what I have.
also curious about comment regarding vertical height between indoor and outdoor unit. I have split system with same units at both locations. The one running now with no problem has about 50' lines with 40 of that being vertical to 3rd FL roof of rowhome.
did both guys get this fixed ?
morriw11 is offline   Reply With Quote
Old 07-21-2011, 08:36 PM   #13
An old Tradesmen
Refrigeration, A/C copper dimension is the OD. So 1/4" measures 1/4" outside dimension.
Old 07-21-2011, 08:50 PM   #14
JJboy's Avatar
http://natureaircorp.com/downloads/r...ifications.pdf
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
rheem new condenser fan motor install help blueaccord19 HVAC 0 04-28-2010 10:06 PM
Residential AC Unit - Can a stalled condenser fan cause other problems? bcphoto HVAC 6 04-03-2010 11:09 AM
Rheem furnace blower problems ellioant HVAC 0 11-24-2009 12:38 AM
Replacing Heat Pump system - Carrier or Rheem? CoolMan74 HVAC 6 06-28-2009 11:13 AM
Rheem Criterion Gas Furnace Problems boons25 HVAC 2 01-24-2009 11:48 AM
