Hello - first post.
I have a 4 month old Rheem 2-stage 90+ gas furnace. It has been working very well this winter, but has developed a problem.
On startup, I am getting a loud vibrating noise. This happens during the 60 second pre-purge before the air blower kicks in, and seems to diminish after the heat has been flowing for a couple of minutes. Everything still works OK, but the noise is not good. It does not happen every single time the furnace starts up, but I have noticed it with some frequency.
To the best of my troubleshooting ability, the noise is coming from the draft inducer, and it sounds to my ears like a bearing going bad :confused1:. When the inducer motor spins down at the end of a cycle, you can hear a quiet rhythmic noise in the rotation as it slows down. It sounds almost like air blowing across the open end of a pipe, I think that this is the source of the noise, only upstairs it's much louder with more vibration since it's going at high speed at the start of the cycle and amplified through the ducts - more like an electric drill.
Nothing seems to be physically vibrating excessively, and for inducer trouble the manual suggests checking for clogs in the condensate lines and exhaust (which I did) or the heat exchanger (which I did not - too hard to easily get inside).
Any thoughts on how to troubleshoot before I pay for a service call? The parts are still under warranty, but labor is not.
