New Register In Overhead Duct - HVAC - DIY Chatroom Home Improvement Forum
Old 04-22-2010, 03:24 PM   #1
new register in overhead duct
Finishing off my basement and I'm soffitting(?) in the furnace supply/duct.
I've added two 6 inch runs to this duct and a return for the room but need to add a register to it which would be directly overhead/below the duct. No new run just directly into it.
The drywall will be right up against the duct. In a previous project I've cut out an opening to fit a register in the duct and then a matching opening in the drywall. Then just added the register and screwed into the duct.
Is this the proper way to do this? Can't think of any other way, thought I'd ask.
mmcc is offline   Reply With Quote
Old 04-22-2010, 04:36 PM   #2
An old Tradesmen
Rewards Points: 6,132
The drywall isn't suppose to be touching the duct.
Old 04-22-2010, 05:22 PM   #3
Well I guess the drywall is not connected to the duct due to the soffit being off it somewhat, but why not? Condensation issue? Inspector had no problem with it.
Anyways, still looking for the proper way to add this register when it's not off a run. There currently is one cut into the duct from when the house was built with a register directly attached to duct. Still the question, how to go thru drywall and into duct work when not using a resgister box at end of a run.
Guess I could build a little wooden frame around the duct opening that is between the drywal and duct?
Old 04-22-2010, 05:33 PM   #4
An old Tradesmen
If the drywall is touching the duct. The duct would be cut that it has flap that extends past the drywall, and then is folder over the drywall.
The corners are then caulked so as not to leak air.
When the sofit is framed away from the duct. Generally. A sheet metal collar is made and installed on the duct before the drywall is installed.
Old 04-22-2010, 05:43 PM   #5
Get the right register for the "throw" that you want.
Old 04-22-2010, 05:56 PM   #6
I like that flaps idea. Didn't think of that...
How to attach ceiling register to duct? adrianm HVAC 6 03-25-2010 08:29 AM
Extend Duct Register philly529 HVAC 2 03-08-2010 05:51 PM
Return duct "boot or no boot" ads67 HVAC 16 01-10-2009 10:38 AM
Attaching Flex duct to register boot avshockey HVAC 15 12-03-2008 09:07 PM
Condensation in Wall: Can I Seal a Dryer Duct With Caulk? xquercus HVAC 5 07-01-2007 03:33 PM
