New Radiant Zone - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-16-2011, 11:06 PM   #16
Angry
thank you very much
i think i may have the electrical correct and will check my notes over the next week/weekend
if you dont mind i would like to confirm my thoughts with you
thanks again
dave
HANDYDAVE1 is offline   Reply With Quote
Old 05-17-2011, 05:20 AM   #17
An old Tradesmen
Rewards Points: 6,108
Your welcome.
Just post any questions you have, and I'll answer them if I can.
I still haven't figured out the meaning of life, so don't ask that one.
Old 05-17-2011, 08:07 AM   #18
Hi Beenthere
i had originally planned on using baseboard for this project and had changed my mind and am instqlling the radiant floor. I had originally run a 3/4 copper pipe(type-m) for the supply to the room. it is approx 75 feet from the boiler
Would you think i can attach the 1/2 pex to that supply and run the pex return back to the boiler or should i make a new run with the pex for the supply side
Old 05-17-2011, 04:22 PM   #19
An old Tradesmen
If the return is going to be 75' long also. then you should run the return out to that room in copper, and then connect the 1/2" pex to those 3/4" copper lines. How long will the radiant loop itself be.
Old 05-18-2011, 07:59 AM   #20
The room is appr 17 x8. Taking off the floor space for the shower, toilet, and under the tub I figured about 170 feet.
I do have in the crawl space under this bathroom a common return from two other rooms and when I was originally thinking of baseboard I was going to pipe the return for this bathroom into this common return.
Am I correct in thinking that the radiant zone needs its own designated return or can I tap into this return for this bathroom also?
If not then your advise is to use the copper supply, connect the pex to it,run the loop for the radiant, then to a 3/4 copper return for the run back to the boiler.
Old 05-18-2011, 04:51 PM   #21
An old Tradesmen
Needs its own return so the mixing/temper valve can control the loop temp. Yes, run copper. since it is less resistive to water flow, it allows you to use a smaller circ. And its easier to balance down water flow, then to use a larger circ to increase flow.
Old 05-18-2011, 04:54 PM   #22
I was pretty sure that was the answer but wanted to confirm
Which circulator do you think I should use 006 007 008
Thanks again for all your help
Old 05-18-2011, 05:11 PM   #23
An old Tradesmen
3 speed 007. Easier to adjust to the needed flow.
Old 05-18-2011, 05:37 PM   #24
Thanks Again
I have a good idea of what I am doing but it really helps to bounce ideas off a pro to make sure I am on the right page
I went to Taco's site and it looks like I want the 00R-MSF1-4IFC
This has the flow check buit in
Is this the pump you are suggesting.
What helps me determine which speed I need to set the motor to?
ANother question if you dont mind. It is about the electrical
So I have 5 zones piped on the boiler .I am using three now, I was going to use a fourth if I was using baseboard for this room and I piped in a 5th for future expansion if needed. So two wont be used at this time but they are all connected up to the ZVC
The are all controlled by a taco zvc405
Everthing is fine
I had told you that an idirect hw heater was added and the oil company changed the aquastat. Again all is fine
I nOw have to add the new radiant zone
The oil company added an sr501 and it controls the circ for the hw
it does not connect to the aquastat or the zvc at all
again all fine
I was thinking of changing the sr501 single zone to a 502 dual zone
What do you think?
It seems the easiest way but they are pricy I could add another 501 but its getting very busy on the boiler
unless I can somehow tap into the zvc
Old 05-18-2011, 05:50 PM   #25
An old Tradesmen
Use this one.
http://www.taco-hvac.com/en/products...nt_category=53
Built in flow check, and it has its own transformer and relay, so you don't have to add any.
How much flow you need, is based on how many BTUs the room needs, and how much tubing you have installed.
The Following User Says Thank You to beenthere For This Useful Post:
HANDYDAVE1 (05-18-2011)
Old 05-18-2011, 07:46 PM   #26
ok thanks
so you dont think i need the three speed version?
Old 05-19-2011, 03:36 AM   #27
An old Tradesmen
Not sure if the 3 speed version comes with the relay set up. So if your looking to save some money, that one will work fine, and you just need a balancing tee to slow flow if its too much.
The 3 speed is nice to adjust flow, but I've never seen one with the relay built in, doesn't mean they aren't made, just I've never seen one.
Old 05-19-2011, 09:55 AM   #28
ok thanks
Going to the supply store
I think this will go smooth I really appreciate all of your help
Dave
new radiant zone to boiler HANDYDAVE1 Plumbing 4 05-10-2011 10:13 PM
3rd zone not working properly MichaelChlopik HVAC 1 10-15-2010 06:59 PM
Adding a radiant heat zone -hydronic experts Joe F HVAC 76 01-27-2010 03:51 PM
Adding new zone makapacs HVAC 0 11-26-2009 01:35 PM
help with third heat zone i just put in... wombosi HVAC 6 04-21-2009 01:02 PM
