Old 06-06-2011, 04:47 PM   #1
new r-410a ac unit installation procedure(w/old unit r-22)?
recently had my house 4ton ac unit changed out and now have several questions...
Old unit was R-22, new unit is R-410A, contractor did not change old refridgerant lines, assuming they were flushed should they have installed a filter and or dryer? I do not see either outside, could they be inside the new unit or are they not required when both inside and outside units are replaced?
Next question about not changing the ac lines-according to info read on these message boards they may be undersized... I looked at the specs-7/8's and 3/8/s, measured the existing lines and i think they are 3/4 and 1/4, is this much of a concern?
if so what could result if left in current state?
also the a/c wouldn't come on 1 day ago, and i found a 30amp breaker mounted in the air handler(in the attic)had tripped, i reset it and it is working fine(last 24 hrs), but what could have caused it to trip?
And last of all after i reset the breaker and unit running, I notice cool air(in hot attic) so after investigating, noted air coming from around condensate drain line and another place.
Can i seal these up with caulk or foam? also found laying on top of air handler what looks to be a rubber plug to go around the drain line if it were cut and fitted...?
If it matters new units are tranes, outside is xr13, inside air handler is 4teh,(all electric)
excalibur1 is offline   Reply With Quote
Boiler Installation - Am I being gouged? mahatmakain HVAC 55 01-29-2010 04:38 AM
Konecto Installation Tidbit jennydavis Flooring 9 01-06-2009 01:19 AM
Electricl Installation for Electric Tankless Water Heater Educator Electrical 13 07-06-2008 11:27 AM
Radon Mitigation installed near AC Unit outside. Problem? majorchamp General Discussion 16 06-30-2008 02:44 PM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 08:46 AM
