New Pipewrap On Cold Ac Line - HVAC - DIY Chatroom Home Improvement Forum
Old 08-05-2011, 03:05 PM   #1
Rewards Points: 190
New pipewrap on cold ac line
Hi!
Before I go about doing this, I thought I'd ask the pro's. How can I add more (or new) pipewrap on the cold AC line outside?
I was out there the other day, and the foam pipewrap that came with the house is soaking wet with water, and it had a couple tears in it. I was thinking of replacing it with a rubber coated one. Before I do this, I wanted to check with people here to see what their thoughts are. Is there a better way to do this? Should I remove the old one and put the new rubber one on? Put the new one over the old one? If I use a rubber one, will water be trapped and cause rusting (oxidizing) on the copper line and cause a leak?
Thanks!
wiz561 is offline   Reply With Quote
Old 08-05-2011, 03:47 PM   #2
Rewards Points: 6,652
It is the same that is used to insulate hot & cold water pipes.
Old 08-05-2011, 04:23 PM   #3
Still Learning
Take off the old insulation, and put new insulation on. Its called rubatex (I think that's how you spell it...) once you replace the insulation there will not be water there anymore. The pipe condinsates for the same reason a soda can does. Once you cover it with insulation then the warm air wont be touching the cold pipe. You can use electrical tape on the ends of the rubatex to secure it, and it looks halfway decent
thehvacguy is offline   Reply With Quote
Old 08-07-2011, 12:04 PM   #4
Rewards Points: 190
thanks for the information! I will be doing this probably next weekend or during the week.
Old 08-07-2011, 01:49 PM   #5
Hvac Pro
yuri's Avatar
Rewards Points: 1,434
AKA "Armaflex".
DIY Comedy--PVC for main water line? Daulton Plumbing 8 03-23-2011 10:03 AM
Hot Water Turning Cold - Could it be the washer/dryer? kissiffer4 Plumbing 3 01-28-2010 05:47 PM
Can a roof vent identify where my main sewer line exits the house? YerDugliness Plumbing 8 01-26-2010 05:13 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
Frozen cold line, not hot... Unregistered Plumbing 1 06-08-2006 08:42 AM
