Hi Folks--
Well my installer's supervisor can't come out for a week, the installer verified pressure and txv and were fine. I decided I'd look at the wiring as I'm pretty technical. The Payne (PH13NA) Heat pump was replaced from a along with my coil. I have a Carrier Air Handler/Furnace (58RAV) and a Carrier Heat Pump Thermostat (TSTATCCPHP01).
The unit works just fine in COOL mode, in HEAT mode, the heat pump kicks on and then goes off a few seconds later. In emergency heat mode, the gas furnace kicks on just fine.
The TXV and Unit is properly charged per the tech. I don't believe the reversing valve is getting signal.
Here is the wiring, - First entry is the Air Handler, Second entry is the Thermostat, third entry is the Heat Pump:
Handler | Thermostat | Heat Pump
Common Common Common
W W W
Y Y Y
R R R
G G -
O O
W = WHITE
Y = YELLOW
R = RED
G = GREEN
COMMON = BLUE
O = BROWN
Any suggestions?
W W W
Y Y Y
R R R
G G -
O O
W = WHITE
Y = YELLOW
R = RED
G = GREEN
COMMON = BLUE
O = BROWN
Any suggestions?
