New Hvac Precharged Unit Install - HVAC - DIY Chatroom Home Improvement Forum
Old 01-30-2009, 03:31 PM   #1
new hvac precharged unit install
the unit is installed i have purged the system and pulled a vacum over 24 hrs to 500 microns. i have 25 ft run and this is a 4 ton precharged condensing unit split system on manufactured home. what is the fill preasure on the evaporater side befor opening condensing side to run the unit? i want to say around 30 psi on the low preasure side.have not done this in a while.
reno1011998 is offline   Reply With Quote
Old 01-30-2009, 03:37 PM   #2
An old Tradesmen
Rewards Points: 6,140
The installation manual will tell you how much to add for the line set length and coil match up.
HVAC unit moves too much air - can I slow the fan down? UtahGuy HVAC 7 12-16-2008 07:06 PM
HVAC filter rack install richers HVAC 3 08-19-2008 02:08 PM
does this sound like a broken/hurting hvac unit? joeyboy HVAC 3 06-28-2008 11:44 AM
Space around the HVAC unit? QueenL HVAC 8 04-16-2008 01:50 PM
