Old 04-03-2006, 04:12 PM   #1
new HVAC & door bell quit
Just had new HVAC unit installed and now the door bell quit working, even the light on the door bell is out. Could the door bell have used the transformer on the HVAC. It is a central system furnace inside ac outside. What wiring should I look for to repair it. AC company says never heard of such a thing. Thanks for the help.
didn'tdoit is offline   Reply With Quote
Old 04-05-2006, 10:16 PM   #2
Angry
Found the problem. The doorbell was connected to the transformer in the old furnace and just not connected to the new furnace... anyone know what terminals to connect the two doorbell wires to? I hate to call the HVAC company to come out just to fix this?
Old 04-15-2006, 01:02 PM   #3
coolmen's Avatar
with the new furnaces now a days they use sensitive control boards.adding the doorbell directly to this is not recommended. your doorbell should have its own transformer and probally did, but was installed on the old furnace. You need( 24/120volt transformer) to operate door bell .this will require some one who knows how to install a t-former. tell the hvac co that the doorbell transformer was mistakenly taken with the old furnace and if they would kindly come back and install the transformer
terminal R and C on board. BEAWARE if you damage something or accidentally damage something (they have the right to charge you for service and parts)
coolmen is offline   Reply With Quote
Old 04-16-2006, 07:30 PM   #4
Thank you.
History of HVAC Industry Brands winkydink HVAC 8 03-25-2011 08:28 AM
New home HVAC wdsfr1968 HVAC 16 03-24-2011 12:26 PM
HVAC plans for remodel wease HVAC 3 03-23-2011 11:47 AM
Do I need a HVAC return vent in basement? westing HVAC 12 01-28-2009 01:09 PM
Walls around HVAC Not Sure HVAC 1 08-15-2006 09:47 AM
