New Hunter 44860 Tstat - HVAC - DIY Chatroom Home Improvement Forum
Old 07-13-2008, 02:41 PM   #1
Unhappy
New hunter 44860 tstat
Hello,
I had a Trane Weathertron(heat pump) thermostat and thought it was time to get a new programmable one, so I bought a hunter 44860. I figured out the new wiring from a nearly 25 year old tstat to this new hunter. After conversion here is what I have:
y1(yellow) - compressor stage 1
w2(cream/white) - auxillary heat
g(green) - fan
rh/r(red) - 24v
o(orange) - reverse valve cool
e(black) - emergency heat
b(green) - reverse valve heat
t(black) - taped up
Cool worked good. Heat didn't work. Used the manual and says try jumping rh with rc/r. Flipped breaker, installed jumper, turned back on. Now nothing, no AC or Heat. I was wondering if there was another fuse or breaker that may have gotten switched, or did I really mess up my furnace/compressor/tstat? Any help on this would be great. Thank you.
-Charles Shemonek
mndevildog is offline   Reply With Quote
Old 07-16-2008, 10:24 AM   #2
Okay, I had my red and black wires inverted on thermostat, the conversion is what messed me up. Ended up frying my transformer... the jumper was required though, for heat to work.
Thermostat Wiring Help Please OHIO HVAC 4 06-01-2008 09:31 AM
Tstat bad or what walker45 HVAC 1 03-10-2008 10:54 PM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 10:10 PM
