New Humidifier Install - HVAC - DIY Chatroom Home Improvement Forum
Old 02-23-2014, 06:57 PM   #1
New humidifier install
I have successfully installed one humidifier on the one furnace and now onto the next one. Second furnace threw me a surprise, no where to install it on the supply side. Return duct is open but where do i install the bypass duct and humidistat? There is an area in between furnace and coil i could attach the bypass duct but unsure to do that and only other way would to run it up to the supply trunk out. Would I install the humidistat above the humidifier on the return side or? again
By the way its a bypass Aprilair 600M on a Trane XV95
14dodge is offline   Reply With Quote
Old 02-24-2014, 08:23 PM   #2
An old Tradesmen
Rewards Points: 5,644
Install the humidistat on the return before the humidifier.
Old 03-24-2014, 05:31 AM   #3
For particular installation project that throw some curveballs, I would suggest possibly calling a professional out to at least survey the situation. It may be worth the 100 bucks to pick the professional HVAC person to see what they would do for installation.
NickNV is offline   Reply With Quote
Honeywell HE260A Humidifier install rdtour HVAC 3 02-02-2011 10:10 AM
Should I install interior doors before floor? pttcc Flooring 13 11-23-2010 10:02 AM
Goodman GMP100-3 Humidifier Issue olds2000 HVAC 1 11-20-2010 11:18 PM
Aprilaire Humidifier, no water? z33tec HVAC 5 11-18-2009 08:42 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 11:42 AM
