New House HVAC Bid - HVAC - DIY Chatroom Home Improvement Forum
Old 01-14-2011, 02:58 PM   #1
Lightbulb
New House HVAC bid
My wife and I are building a new home this year. Our contractor gave our house plans to his HVAC sub, and the bid came back at $39k. This is a 3100sq/ft ranch with a walk-out basement. Good size home but not really the Taj-Mahal. Their bid called for dual geotherm heat pumps. I love geotherm but thought the bid of $39k was really high. 1st question: If we insulate well (ie spray foam etc) do we even need geotherm? this sub is a Trane dealer and they have a 20 seer conventional heat pump with an ultra high gas furnace. Not sure what that bid would be but would imagine it is a lot less than $39k. 2nd question: Are dual systems even needed? The important reason "we need" 2 systems (they say)is so we will be able to zone heat and cool. Just came from a meeting with the sub and can't help but think he is "pushing" this system because is cost the most and therefore more profit for him. Am I wrong?
CentralIL is offline   Reply With Quote
Old 01-14-2011, 03:25 PM   #2
Rewards Points: 6,652
Geo would be the best way if you have the land space for it. 39k is in line with Geo.
Old 01-14-2011, 06:29 PM   #3
An old Tradesmen
Rewards Points: 6,928
You can "zone a single unit.
Spray foam would allow you to get 1 geo and zone it. Or get a single conventional hybird/dual fuel system, and zone it.
Geo is expensive to install.
Old 01-14-2011, 06:58 PM   #4
sktn77a's Avatar
Rewards Points: 392
Did you specify geothermal in the house plans? That will typically double the HVAC costs over typical split system furnace and AC. Which sounds about right for 2 complete new systems with the heat distribution network, etc ($20k). Those are prices for top of the line systems, not "builder" grade.
sktn77a is offline   Reply With Quote
Old 01-14-2011, 08:18 PM   #5
I guess we did specify Geothermal. Our contractor was really for it when we talked to him early on in the process as the plans were being drawn. It wasn't a "last minute change" for sure. It thought there were ways to zone a single system. We are new to the building process. Thanks for the info so far. What I have read...people always talk about "payback" for the systems. It would seem to us that if we had an "ultra-insulated" house the payback would be incredibly long.
Old 01-15-2011, 04:01 AM   #6
An old Tradesmen
The tighter built, and better insulated the house, the longer the pay back. but the bill is also that much lower.
You also would only need 1 geo then, instead of 2. Which would lower the up front install cost.
Old 01-15-2011, 02:46 PM   #7
Rewards Points: 280
Did the HVAC sub do a load calculation for heat gain/heat loss?
If it were my house, I would want to see/have a copy.
Earnie is offline   Reply With Quote
Old 01-15-2011, 10:19 PM   #8
sktn77a's Avatar
Rewards Points: 392
Two level homes generally benefit from two systems. But you have a single level ranch so you should be able to use a single system (given that the basement is inherently a lower load space).
Tags
hvac
replumbing an old house simonfrog Plumbing 7 01-30-2012 04:45 AM
Thoughts and ideas basement finishing and HVAC creamaster HVAC 1 03-10-2010 07:46 PM
Trane XR12 1.5 ton-Too small for my house? Badfish740 HVAC 7 09-23-2009 05:48 AM
My new project, 31 year old house... Axhammer General DIY Discussions 3 04-08-2009 08:46 AM
EXcessive moisture in house geema HVAC 5 09-10-2008 11:18 AM
