New Honeywell Thermostat Connected To Old Climatrol Heat Pump - HVAC - DIY Chatroom Home Improvement Forum
Old 08-24-2010, 10:52 AM   #1
Question
New Honeywell thermostat connected to old Climatrol heat pump
Hi,
I recently bought a Honeywell thermostat RTH7600D to replace an old thermostat (containg a Mercury tube) in my condo.
Heat pump is 20+ years old Climatrol 753-2-18W-10.
The old thermostat is a Kepro 1262-1 (?) and had the following wires connected:
Green wire to G-F
Yellow wire to Y-C
Red wire to R-V
Black wire to W-H
I've followed the Honeywell instructions and connected the wires as follows:
Green to G
Yellow to Y
Red to R
Black to O/B (??)
Cooling works fine but when I turn the heating on and set the temperature to higher than room temperature it keeps on cooling - which seems to indicate that the changeover valve is not connected properly (tired both setting it to 0 and 1 in the thermostat options).
Any suggestions?
Thanks a lot.
Thomas
olorintf is offline   Reply With Quote
Tags
climatrol , heat , honeywell , pump , thermostat
Rheem Heat Pump & Honeywell VisionPRO infoskr HVAC 2 11-20-2013 06:08 PM
New Install - Heat Pump Woes... mark1210 HVAC 7 03-07-2010 10:14 AM
New Heat Pump..questions? ddave23 HVAC 4 03-05-2010 06:13 AM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 08:40 AM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 12:49 PM
