Old 09-19-2007, 09:59 AM   #1
new honeywell rth6300b to replace very old honeywell thermostat
i have purchased a new honeywell thermostat (rth6300b) to replace an old honeywell thermostat. the only 2 wires from the old thermostat are RED and BLACK with no letter designation anywhere. i only have a heating system with no cooling, the heating system i have is a hot water system with radiators, a gas boiler with a pump. First of all, to help me better understand, what type of heating system do i have? where does the red and black wire go to on the new honeywell digital programmable thermostat? the possible slots on the new honeywell are as follows
G - W(O/B) - NOT USED - Y - R - Rc
I apprciate all your help!
Designman20
Designman20 is offline   Reply With Quote
Old 05-06-2009, 02:56 AM   #2
You mean the thermostat that you have purchased, a new honeywell thermostat (rth6300b) to replace an old honeywell thermostat... How is the difference??
_________________
Programmable Thermostats
MayDix2009 is offline   Reply With Quote
Old 05-06-2009, 05:43 AM   #3
An old Tradesmen
If the new thermostat is battery operated.
R and W.
If it needs power from the boiler, wrong thermostat.
Or you will need to run more wires.
You have a hot water boiler system.
Honeywell Thermostat code 0340-reset? George Foote HVAC 3 02-14-2011 01:52 PM
honeywell chromotherm thermostat - help? mkbgriffen HVAC 4 12-26-2006 01:46 PM
Lux 722E Thermostat mgkicker HVAC 3 10-27-2006 02:40 PM
Honeywell Electric Thermostat Model T498 staylori HVAC 1 01-14-2006 01:25 PM
