New Home HVAC Installation - HVAC - DIY Chatroom Home Improvement Forum
Old 07-11-2011, 09:57 PM   #1
New home HVAC installation
Hello,
I'm considering buying a new home package from 84 lumber. I need to estimate what the costs would be for putting in the HVAC system. It's going to be a 1300 sf house. Anyone know what I would be looking at?
Thanks!
jgodinez is offline   Reply With Quote
Old 07-11-2011, 10:48 PM   #2
Work Hard, Play Harder
Rewards Points: 212
Originally Posted by jgodinez View Post
Hello,
Thanks!
I have 1900 square feet; spent 10,500.00 on a complete setup with 2 zones. Included Luxaire LP9C*C, UltraVation progressive media air cleaner and having my existing AC hooked up (new core though).
coderguy is offline   Reply With Quote
Old 07-12-2011, 06:40 AM   #3
Depends on what you get and how much of the labor you do. A builder grade is half the cost of a high end air to air heat pump with gas back up. A geothermal will be twice the cost of a high end air to air.
Old 07-12-2011, 09:25 PM   #4
Thank you so much for your input. That is exactly what I was looking for!
Old 07-12-2011, 11:11 PM   #5
Rewards Points: 212
Make sure taping/sealing/etc is noted in the contract.
Mine also included a pump because we didn't want to run the water across the floor. The more efficient the furnace, the more water. I believe it is called a "little giant"; as the water comes out of the furnace it is pumped over to the sink.
Need home plans for a simple barn home! RUMBLON General DIY Discussions 0 06-02-2011 03:05 PM
New home HVAC wdsfr1968 HVAC 16 03-24-2011 11:26 AM
New HVAC installation concern CoverZero HVAC 23 01-11-2011 04:18 PM
Damaged Vapor Barrier during home theatre installation..should I be worried? wasserkool Building & Construction 2 03-03-2009 02:53 AM
A facelift for your home Grumpy Remodeling 0 07-07-2004 07:43 PM
