New Home - Furnace/coil Question - HVAC - DIY Chatroom Home Improvement Forum
Old 07-10-2012, 12:21 AM   #1
New home - furnace/coil question
We're having a new home built and had a Tempstar VS95 gas furnace installed in the basement for our central air/heat system. However, the coil that was placed on top of it doesn't line up exactly right - we could feel the air escaping from the gap. When we told the installer, he first sealed it up with tape. He has since replaced the tape with caulking. Does this sound right?
NewOwner32 is offline   Reply With Quote
Old 07-10-2012, 06:05 AM   #2
First - what do you mean by "doesn't line up exactly right"? On a brand new system the furnace + coil should have been matched up, and the coil case should almost always be the same width as the furnace. There will sometimes be a slight offset (an inch or two, perhaps), but that should be properly sealed with metal plates, screwed in place and sealed with tape or caulk.
That said, we use silicon to seal between an upflow furnace and a coil, but you could certainly use tape as well.
scottmcd9999 is offline   Reply With Quote
Old 07-10-2012, 08:51 AM   #3
Rewards Points: 6,652
I have a gap around my A-coil and my furnace where it sits, and there is not much air that gets pass it during cooling. Majority of the air will seek the largest opening, which will be in the middle of the a-coil. Personally if you do not like how it is now during the building phase, stop the work and have the HVAC contractor fix it.
It is your money. Do you want to waste it, or tell it what to do for you?
Old 07-10-2012, 07:13 PM   #4
AKA HVACTECHFW
Rewards Points: 1,208
Pictures?
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
1938 TN Home - My First Home, My First project, Tons of Pictures!!! Firefighter3244 Project Showcase 78 07-01-2014 11:55 PM
Moisture on windows baum Building & Construction 56 12-22-2009 06:39 PM
rewiring older home question? nt4sell Electrical 7 12-16-2009 07:02 AM
Pay GC to construct home and finish it myself? L O N G . . . Badfish740 Off Topic 9 07-27-2007 09:44 AM
A facelift for your home Grumpy Remodeling 0 07-07-2004 08:43 PM
