Old 04-16-2008, 10:47 PM   #1
New High Efficiency Gas Furnace & Hot Water Heater
I am installing both a new gas furnace and a new gas hot water heater. Both are high efficiency appliances that can be vented with PVC (exhaust & intake). My question is, can I tie the two appliances together to reduce the penetrations from four to two? If not, how far apart do the terminations have to be spaced? Both appliances will be installed in the basement and vented through the wall. Also, what rules are there for proximity to windows or doors?
frank08226 is offline   Reply With Quote
Old 04-17-2008, 09:19 AM   #2
No you cannot. If you read the literature from either of the 2 units, it will state as such.
Your local venting code may vary, but here it's no vent within 10' of any window or door, or other venting apparatus such as bathroom exhaust, clothes dryers, kitchen fume hoods, through-wall a/c, etc...
LawnGuyLandSparky is offline   Reply With Quote
Old 04-17-2008, 01:06 PM   #3
Thanks, haven't purchased the equipment yet so haven't read the literature. Just planning on where my penetrations will need to go.
New High Efficiency Furnace Problem Buster 567 HVAC 8 12-13-2010 09:36 PM
high efficiency gas furnace hammer6315 General Discussion 2 06-18-2008 11:25 PM
Water heater problem bear1957 Plumbing 23 11-01-2007 04:53 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 07:01 PM
