New Heating System In Old House - Needs Lots Of Help - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 09-19-2012, 06:49 AM   #31
Rewards Points: 79
Still chasing this down. I woke up this morning to about 37 degrees outside and around 62 inside. I have an infrared thermometer and went around checking walls. All walls and floors came out at within a couple degrees of 60 including interior and exterior. The door and windows were between 55 and 60. Doesn't this indicate decent insulation?
The same is true both upstairs and down.
beengone is offline   Reply With Quote
Old 09-19-2012, 01:00 PM   #32
Missouri Bound's Avatar
Even the airspace in the wall will offer some insulation. Open a wall and look. You are going to remodel anyway which will give you the opportunity to insulate as you go. You can't have too much insulation in my opinion. Don't overthink this remodel. Get yourself a comprehensive plan and stick with it.
Do you want it your way or the right way?
The Following User Says Thank You to Missouri Bound For This Useful Post:
beengone (09-19-2012)
Need advice RE: purging air from baseboard hot water heating system mikenri HVAC 2 01-19-2011 08:17 PM
Open Hydronic Heating System... how / need to bleed? MtnMan7 HVAC 1 11-19-2010 04:51 PM
New Heating & AC system takes long time to warm up home poston8 HVAC 10 11-10-2010 04:26 PM
Installing a New Central Air System vdu HVAC 7 09-01-2009 04:45 PM
Heating Retrofit in a Victorian Multi-Family House mumphis HVAC 1 09-30-2006 11:36 PM
