New Heater Vibration - HVAC - DIY Chatroom Home Improvement Forum
Old 01-05-2008, 09:36 AM   #1
Rewards Points: 16
My heater died Christmas weekend and had to have a new one installed.
The unit was replaced by a Meridian 100,000 BTU Gas furnace.
The unit heats the house nicely but I am noticing one problem that was not in existance with my old Lenox unit.
TGhe duct work traveling vertical from the unit vibrates a lot - its seems almost as if the sides of the duct work push in and out when the unit is running. Also affected is the horizontal branched off duct work in close proximity to the unit.
Seems like everything else is working fine but the vibration can actually be heard on the first floor in the wall also ust above the heater.
Any idea what might be causing this?
captainron19 is offline   Reply With Quote
Old 01-05-2008, 09:49 PM   #2
Was any of the duct work changed or modified?
redline is offline   Reply With Quote
Old 01-05-2008, 09:58 PM   #3
Union HVAC Tech.
Call the installer back and tell him to fix it, it never made those noises before. He may have to add a canvas collar and vibration pads under the unit.
bigMikeB is offline   Reply With Quote
Old 01-06-2008, 10:43 AM   #4
Rewards Points: 16
No the duct work was not touched except where it connects into the heating unit
Old 01-06-2008, 03:41 PM   #5
biggles's Avatar
might of lft the fan in hi fan connection for an a/c application you need a med/lo for heating this a call back for the installer to reboot the motor speed wiring.
Water heater problem bear1957 Plumbing 23 11-01-2007 04:53 PM
Installing a tankless water heater ? bdalekid Plumbing 3 02-26-2007 08:26 PM
Wiring electric heater in bathroom PatSea Electrical 5 01-06-2007 10:40 PM
Baseboard heater Help! jweinstock Electrical 6 10-28-2006 05:01 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
