New Heat Pump..questions? - HVAC - DIY Chatroom Home Improvement Forum
Old 03-03-2010, 07:33 AM   #1
We recently renovated our attic space to create 2 large rooms. We had installed a 2 ton Whirlpool Heat Pump w/7.5kwh electric strip.
I have never owned a Heat Pump before, so I am new to all of this. It appears the Heat Pump is always running?? I have set the temp in the attic to 68 and the Heat Pump seems to run constantly.
It has been cold here in MA (low 30's to 40's) but I was not sure if the Heat pump is trying to maintain the heat at 67? The attic is insulated well (spray foam) and the aux heat does not kick on unless there is a 3 degree temp differential...from my understanding. I have tested this and the aux does come on if I set the temp 3 degrees higher…
Is this what I can expect from the Heat Pump? to be constantly on? I would image that this would do some damage to the electric bill??
Sorry for asking these newbie questions, I just want to get a feel for what everyone thinks..
Thanks,
ddave23 is offline   Reply With Quote
Old 03-03-2010, 05:25 PM   #2
An old Tradesmen
Rewards Points: 8,194
Not uncommon for a heat pump to run a lot and constantly when temps are in the low 30s.
How big is the attic.
Old 03-04-2010, 01:56 AM   #3
Just suggesting
It is possible that your heat pump is undersized for the fixture that it is supposed to cool and also when there is a great temperature differential between the fixture and outside temp you will see a faster rate of transfer or heat loss to the outside because heat flows from hot to cold so it wants to get outside. I would suggest insulating the rooms more or possibly looking at a higher btu output heatpump.
Aaron87642 is offline   Reply With Quote
Old 03-05-2010, 04:20 AM   #4
Heat pump sizing depends on a lot of factors...ie...new or old windows..insulation..SIZE OF AREA to be heated/cooled. Assuming it was sized correctly...poke a hole in the supply plenum and take a temp. reading and then poke a hole near the furnace in the return air plenum...the temp. should be about 22 degrees difference Fahrenheit(higher on the supply side). If it's only 10 degrees or 12 degrees...the unit is probably undercharged or has a leak. The auxiliary heating strip/strips usually only raise the temperature another 40 degrees or so.
They sell digital thermometers which you can buy at Lowe's or Home Depot which will fit into small holes poked.
Affordable7 is offline   Reply With Quote
Old 03-05-2010, 05:13 AM   #5
An old Tradesmen
Temp rise will depend on both the outdoor temp and indoor temp at the time of measurement.
At his posted, some units will only have a rise of 16, and will be working as they should. others may have a rise as high as 24°F at his posted temps.
CFM needs to be verified in order for a temp rise check to mean anything.
Temp rise with the aux heater on should never be taken in the supply plenum, as it will give you a false temp rise.
Heatpump vs Natural Gas - Energy Cost Spreadsheet zootjeff HVAC 11 06-22-2015 03:59 AM
Heat pump ice up signpainter HVAC 9 01-02-2012 09:44 AM
Heat Pump Control Wiring Questions IBuiltPools HVAC 3 01-14-2010 01:45 PM
Brand new Carrier Infinity 16 Heat Pump Stopped Working I think needmyac HVAC 3 07-07-2009 06:12 PM
Heat Pump vs Aux Electric Heat batolson HVAC 16 01-17-2009 10:28 AM
