New From Goodman - HVAC - DIY Chatroom Home Improvement Forum
Old 03-18-2011, 07:54 AM   #1
hillbilly guru
Send a message via Yahoo to hvacguytn615
new from goodman
a local dist just had a class on new comunicating system from goodman i know trane and carrier has had this out for some time.i am wanting to here what you think if you have attended one of the classes or have installed or serviced one of the new systems thanks
hvacguytn615 is offline   Reply With Quote
Old 03-18-2011, 10:58 AM   #2
new from goodman
The communicating board is very cool however out is expensive and you must have a communicating a/c-h/p.it makes troubleshooting easy and allows for maximum comfort
heatycooly is offline   Reply With Quote
Old 03-19-2011, 02:39 AM   #3
HVAC Supermodel
unicursalhex's Avatar
Rewards Points: 150
new from goodman
I like the heat pumps, I've installed a few DSZC's. They are much cheaper than other manufacturers 2 stage communicating units and the HSPF is really good on them as well. Not a big fan of the stupid ass thermostats though, I did a full communicating system almost a year ago and the damn stat would kick the furnace on whenever the set temp would get 3 degrees higher than room temp with no way to change it. retarded.
Mark it zero!
unicursalhex is offline   Reply With Quote
** Opinions on a new GOODMAN AC unit ** rms8 HVAC 35 05-06-2012 11:38 AM
Goodman air handler adjustment Xander08 HVAC 2 12-24-2009 03:32 PM
Nordyne condenser goodman A-coil wtroger HVAC 10 09-16-2009 04:52 AM
goodman furnace nhicks HVAC 3 02-09-2008 07:25 PM
Sub is swapping Amana for Goodman Dragon HVAC 22 02-04-2007 08:54 AM
