New Furnace Won't Fire Up - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-12-2012, 07:27 AM   #16
Rewards Points: 960
Just unscrew your flex connector where it enters the furnace and turn the valve on and enjoy the aroma. Then you'll know you have gas.
cleveman is offline   Reply With Quote
The Following User Says Thank You to cleveman For This Useful Post:
Jim33 (04-12-2012)
Old 04-12-2012, 09:54 AM   #17
how
Rewards Points: 1,104
Quote...
My water manometer shows about 9” WC when screwed into the inlet side of the gas valve.
I don't get the flex connecter conversation here. Just what do you think the manometer is measuring downstream of the flex connecter?
how is offline   Reply With Quote
Old 07-26-2012, 10:31 AM   #18
Rewards Points: 610
Gas valve regulator requires adjusting to allow flow through the gas valve OR gas valve may be air locked..disassemble to vent diaphragm and reassemble..had this happen to me on a boiler start up for a school..boiler equipped with 2 inch gas regulator but it would not allow gas flow..took it all apart to look for blockage or defects but did not find any..reassembled and all worked fine..OR you have a defective gas valve that is bound or seized and will not open even though you hear the solenoid click.. Let us know how you make out. Good luck!
techpappy is offline   Reply With Quote
Old 07-27-2012, 07:01 PM   #19
Rewards Points: 83
One of your springs is plrobably messed. Ensure you have the valve wired correctly. Do you have a part number or picture for the valve? There is also a pilot flame adjustment screw, make sure that is adjusted so you get enough gas.
How much manifold pressure does the unit require. 9" sounds a bit low IMHO for lp pressure. Take a lighter to the pilot as well, sometimes the spark igniter still sparks but isn't hot enough or in the right place.
Protocol. is offline   Reply With Quote
Old 07-28-2012, 05:38 AM   #20
HVAC Contractor
Rewards Points: 336
On a 95% furnace with an ignitor? I don't think so ...
scottmcd9999 is offline   Reply With Quote
lint/dust from furnace uksparky HVAC 15 02-16-2012 05:01 PM
Changed gas ball valve and York furnace won't fire, please help. philsoldat HVAC 35 11-03-2010 11:12 AM
furnace indicates calling for heat but no fire pocketrods HVAC 1 10-29-2010 08:09 PM
my furnace wont fire... please help! chrider88 HVAC 7 01-22-2010 09:43 PM
Luxaire furnace fails to fire cheesegrump HVAC 1 01-10-2006 07:36 PM
