New Furnace Venting - HVAC - DIY Chatroom Home Improvement Forum
Old 01-29-2012, 02:18 PM   #1
New Furnace venting
I wanted to thank the community here for all the help in diagnosing my HVAC issues. I am resigned to replacing my furnace with a hi eff unit but have questions on the install particularly the venting As i have installers give quotes
Due to logistics: windows and other structures it appears the best option may be to use the existing furnace chimney to vent vertically rather than a outside wall. I sense some installers do not want to climb on the roof in this weather
1) How is this done: will the installer run PVC up to the top of the chimney from the furnace so that 2 pipes are visible?
2) do I need a liner as well?
3) what should the ends of the vents look like given the openings will be very close to one another: angled in different directions?
Liberator is offline   Reply With Quote
Old 01-29-2012, 02:36 PM   #2
REP
The installation manuel that comes with the particiuliar furnace you purchase will have very exact instructions on its venting and venting termibnations.
Differant companies have differant requirements.It would be very wise to follow those instructions to the letter in order to avoid future problems.
Using the old chimney as a chase is usually allowable and the old chimney needs to be sealed both at the roof and at the start in the basement.
Now if the old chimney will be used to vent the exhisting water heater then you will not be allowed to use it as a chase for the furnace.In that case you could run B-Vent for the water heater using the old chimney as a chase.
REP is offline   Reply With Quote
Old 01-29-2012, 02:46 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 92
Yep, they must follow the venting info in the manual EXACTLY or it can have pressure switch tripping problems etc. Where I am the gas inspector will literally use those instructions and red tag it if not followed properly. I hear that Ontario is very picky too. They vent them all winter long and climb up on the roof or hire a Pro chimney repair co to do it for them. You cannot vent the water htr into the chimney or it will melt the pipes so an electric one is required or a thru the wall type and that may not work because of your windows issues etc. I would go electric as a thru the wall type may cost $1500 or more and don't last any longer than the basic ones. You can buy a tankless one but they are $2000-3000 and have venting issues as well. The Lennox ones have a very clean neat configuration with the exhaust sticking straight up and one elbow to the side for the intake rather than some dog eared looking setup like some other nameless brands.
The Following User Says Thank You to yuri For This Useful Post:
ben's plumbing (01-30-2012)
Old 01-29-2012, 02:57 PM   #4
Sorry I forgot to mention that I just installed a new electric hot water heater recently so there is no venting required for the tank.
Are vertical venting installs more problematic than side exterior venting for the pressure switches?
Old 01-29-2012, 02:58 PM   #5
how
Rewards Points: 1,104
hey Yuri
I saw an installation last week that was a few years old that had a single chimney used as a chase for a B vented HWT and the PVC lines for a 90%.
It was a new one on me and I wondered why I hadn't seen it before since it had been inspected, approved and lot's of folks with furnaces in the center of their homes ***** at routing the vent lines through to the outside walls of their homes.
how is offline   Reply With Quote
Old 01-29-2012, 04:01 PM   #6
REP
Hey HOW! Absolutely nothing wrong with b-vent and plastic venting using the old chimney as a chase as long as the 1 inch is maintained between them.
The only problem would be if in an old house the lenth of the vent exceeded the requirement..
The Following User Says Thank You to REP For This Useful Post:
Old 01-29-2012, 04:04 PM   #7
Hvac Pro
yuri's Avatar
Rewards Points: 92
I have not seen it done that way as a 4" B vent must be 5" OD and the 2" PVC venting is 2.5" OD so you would need a full 8" chimney which is kinda rare these days. Most have been lined already so that old liner would need removing etc but it do-able if the inspector allows it. Would make for a difficult cap on top to seal it from rain etc especially in your area. That seems to be the biggest drawback is how to seal it at the top. How do U guys do it? Slather silicone around a cap with holes cut in it?
Old 01-29-2012, 04:05 PM   #8
Hvac Pro
yuri's Avatar
Rewards Points: 92
Not really but birds can nest up there and who want to climb up there and deal with any blockages later? I avoid vertical venting like the plague.
Old 01-29-2012, 04:26 PM   #9
how
Hey Yuri
Many homes here already have large overhanging chimney caps to deal with the constant horizontal rain which nicely cover our silicone & metal cap slatherings.
Almost all the 90% are going through the wall for simplicity and reliability.
The Following User Says Thank You to how For This Useful Post:
Liberator (01-29-2012)
Old 01-29-2012, 04:36 PM   #10
Hvac Pro
yuri's Avatar
Rewards Points: 92
My Cousin lives in Abbotsford and says the rain is a huge issue ( he is a homebuilder ) as it gets in the cracks of stucco and walls rot and they have to put zinc strips on some roofs to prevent moss growing etc. I love visiting BC (went kayaking with the Orcas) etc but prefer my dry but cold climate.
I guess if done properly (unlike the leaky condo scandal yrs ago) you guys can deal with the rain.
Old 01-29-2012, 04:40 PM   #11
One thing that the OP should keep in mind, in the wrong situation, 90 + vent pipes can and do sometimes form ice balls and freeze, if its side wall vented this is an easy fix.......not so easy when its vented on a roof peak.
Yes a old chimney chase can be used, but only as a final alternative should it be used.
harleyrider is offline   Reply With Quote
Old 01-29-2012, 04:49 PM   #12
Hvac Pro
yuri's Avatar
Rewards Points: 92
The high end Lennox SLP mod and the high end Carriers have an ecm ventor fan which can compensate for some of the blockages but not all. Not sure if any other brands have an ecm ventor.
Old 01-29-2012, 04:51 PM   #13
Yes, I have a large new slab overhanging onto of the chimney as a cap. When I look down from the roof into the chimney, there is a 5" aluminum venting coming up partway up the chimeny for the existing furnace.
There is no other liner on the concrete blocked furnace chimney.
Originally Posted by how View Post
Hey Yuri
Old 01-29-2012, 04:54 PM   #14
An old Tradesmen
Rewards Points: 7,770
York mod's have VS ECM venters.
Old 01-29-2012, 05:19 PM   #15
Hvac Pro
yuri's Avatar
Rewards Points: 92
Partway?? Hopefully the chimney is perfectly straight/vertical and NOT offset or you will have a HUGE problem. If offset then they have to bust open the chimney from inside or outside the house to glue and offset the pipes. beenthere and done that and it ain't pretty.
Natural Gas Cost For Furnace 1 Hour Run Time hammerlane HVAC 25 01-14-2015 02:13 PM
Furnace venting questions Mastiff HVAC 9 12-05-2012 05:51 PM
Furnace Venting Question jlaky2000 HVAC 6 10-10-2011 06:24 PM
Horizontal Venting of Wood Furnace ejfitzpatrick HVAC 2 10-17-2009 06:16 PM
venting a high efficiency furnace through the roof (how high) allAboutDIY HVAC 11 10-21-2008 12:48 PM
