New Furnace Not Running - HVAC - DIY Chatroom Home Improvement Forum
Old 05-12-2012, 05:14 AM   #1
New furnace not running
A goodman furnace new,Install try the AC when back to the house few weeks later,and there no power to the furnace,electic is on the house can it be a wire some where?
louie
louie917 is offline   Reply With Quote
Old 05-12-2012, 05:22 AM   #2
An old Tradesmen
Rewards Points: 6,060
Made this its own thread.
Old 05-12-2012, 06:24 AM   #3
biggles's Avatar
try FAN/ON from the stat shows 24Vs in the furnace if it runs.is stat set for AUTO or COOL(if in heat mode cooling is locked out).set stat for COOL and all day time modes to 60F,check disconnect outside ON?lets hear back on what is running or not
Old 05-12-2012, 09:37 AM   #4
Check the low voltage wiring at the furnace. Sounds like someone hooked Y from the thermostat to C on the furnace and blew the low voltage fuse when the call for cool started.
Old 05-13-2012, 12:00 AM   #5
Rewards Points: 1,910
If there is no power to the furnace check the circuit breaker (and the switch if there is one).
Old 05-13-2012, 09:23 PM   #6
HVAC Tech/ Browns Fan
I if it has a condensation pump. I can be full and trip on over flow switch
Tator1076 is offline   Reply With Quote
Old 05-13-2012, 09:26 PM   #7
Rewards Points: 6,652
louie
Did it not get tested when it was installed? If it does not work now, check the thermostat, if that does not change things, when you turn it to Fan On, or A/C and lower the temp, then call the company that installed it.
blower motor on the furnace keeps running. esidros HVAC 6 03-06-2012 10:56 PM
Pilot Ignitor Starts After Furnace Has Been Running Dr_Zoidberg57 HVAC 0 02-04-2012 06:45 PM
main burner goes out after furnace running 10 -2 0 mins marion60 HVAC 4 11-02-2011 10:53 AM
Gas Furnace Fan Occassionally Keeps Running After Burner Shutdown Dr_Zoidberg57 HVAC 18 11-10-2010 09:52 PM
Long running furnace hurt heat exchanger? quincy HVAC 6 11-09-2010 07:01 PM
