New Furnace Install - HVAC - DIY Chatroom Home Improvement Forum
Old 10-22-2011, 04:31 AM   #1
new furnace install
hello all, im planning on changing out my old carrier 130,000 btu furnace for a new 90,000 Goodman GKS90905DX, my house is about 1800 sq/ft so i need to figure out the size of the new plenum and the new cold air return transition.
my biggest concern is, this new furnace is about thirteen inches lower so my n-coil is going to have to be lowered which is a good thing. if i drain the system of refrigerant and cut the lines during the installation is there a time limit that i have before the system has to be recharged or can i wait till spring?
thanks for any input
Dom
dominic58 is offline   Reply With Quote
Old 10-22-2011, 05:39 AM   #2
raylo32's Avatar
Rewards Points: 1,294
Can't help on the transition but you want to minimize the time the lineset is open to the atmosphere. If you are going to leave it until spring you could cap the ends, evacuate and put in a little nitrogen. The coil is also a concern for oxidation. So really better to put it all back together now and get the air out.
Also, you shouldn't and don't need to "drain" the refrigerant. Look up how to pump a system down to capture the refrigerant in the outside unit.
If you lower the height of the furnace you will have to extend the lineset to reach the new coil position... or get a sheet metal spacer made to go between the furnace and coil to keep the coil at the height it is now. I just went through this and had a spacer made. Mine was a 7" difference.
Dom
raylo32 is offline   Reply With Quote
Old 10-22-2011, 05:57 AM   #3
thanks ray, yes ill need to have the lines extended, dont they have to be brazed vs. soldered? thanks for the tip on pumping down the system i just read a short article on it and think ill have a tech do this and seal the lines during this time and have him come back out and put it back together.
Old 10-22-2011, 06:04 AM   #4
raylo32's Avatar
Yes, brazed. Finding small pieces of HVAC tubing isn't easy... they are typically sold in complete rolls of various lengths. But if you have a tech do the work he should have access to these items.
Need Help With Furnace Install 67Dart440GT HVAC 6 10-20-2011 08:40 PM
Install Help on 75K BTU Garage NG Furnace live4spd HVAC 23 10-15-2011 07:58 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
Installing a new Furnace, Shoud I install an A/C Coil Now? hartkem HVAC 1 11-10-2008 09:31 AM
How to install an expansion tank in my hot water furnace? DanBress HVAC 18 10-08-2008 03:57 PM
