New Furnace Choice - HVAC - DIY Chatroom Home Improvement Forum
Old 03-15-2012, 07:13 AM   #1
Rewards Points: 121
New Furnace choice
This i know may not be easy and usually you get some liking certain models ..but is there one furnace here that does stand out better then the rest...
If i go to a new furnace, having a single stage installed now,, i am thinking of a dual stage furnace, as hydro here in Ontario is very costly, so i want to save electricity..here are 3 choices
Keeprite - Hi Eff. Gas Furnace - Two Stage - Variable Speed - DC Motor - 96% AFUE - Natural Gas - 80000 BTU - G9MXT080-IIX96 -
Ruud / Rheem - Hi Eff. Gas Furnace - Two Stage - Variable Speed - DC Motor - UP FLOW - 95% AFUE - Natural Gas - 75000 BTU - RGRM-07EYBGS -
Carrier Performance 96 - Hi Eff. Gas Furnace - Two Stage - Variable Speed - DC Motor - Up to 96.7% AFUE - Natural Gas - 80000 BTU Ė 59TP5A080 - $2480
rick31797 is offline   Reply With Quote
Old 03-16-2012, 01:17 PM   #2
Rewards Points: 29
Go with the Carrier 96.7% effiency!
spinfisher is offline   Reply With Quote
Old 03-17-2012, 01:07 AM   #3
both the ruud and the carrier are good furnaces, but remember all furnaces models and brands are good (there is no such thing as bad equipment only bad installers) with tha being said if you get top notch equipment make sure you get top notch installation with it
heatingman is offline   Reply With Quote
The Following User Says Thank You to heatingman For This Useful Post:
ben's plumbing (03-17-2012)
Old 03-17-2012, 07:37 AM   #4
Rewards Points: 121
I keep hearing that statement and i am not sure what it means.You don't mean if its installed wrong, a furnace is going to break down more often..
you must be talking about the performance
Old 03-17-2012, 09:55 AM   #5
Thats exactly what it means.
A furnace is only as good as the way it's installed.
Does not matter the brand.
Until an indestructible, fool-proof furnace is invented there will never be a "BEST FURNACE".
hvac5646 is offline   Reply With Quote
The Following User Says Thank You to hvac5646 For This Useful Post:
Old 03-17-2012, 06:56 PM   #6
Rewards Points: 29
Originally Posted by hvac5646 View Post
thats exactly what it means.
Until an indestructible, fool-proof furnace is invented there will never be a "best furnace".
ditto!
Old 03-17-2012, 07:13 PM   #7
Rewards Points: 121
furnace
The only problem, is not all HVAC Technicians are created equal..I am finding that out not trying to get an old furnace fixed...
You may find a good company,but with several employee's some may be better then other's so in the end the furnace may work fine but maybe could have worked better..there are no guarantees
Old 03-17-2012, 09:39 PM   #8
REP
One way to know which contractor to go with is by knowing which one(s) did a real load calculation.The one(s) that didn't are lazy azzz contractors and likely will give you a bad install.
Another thing is that Keeprite is a fairly new brand.Are you sure they will be around in 8-10 years when you might have problems with your furnace?
Another thing to look at is how many people sell which brand.The brand with the most listed contractors tells you that if your contractor can't get to you when (if) you have trouble then there are other contractors with experience on your model furnace.
Another thing you should do is get referances from past customers of contractors.I usually suggest 5 ,and then call them to find out how satisfied they are.
REP is offline   Reply With Quote
Old 03-17-2012, 09:45 PM   #9
Rewards Points: 121
furnace
excellent information, it all makes good sense ... thanks
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 05:01 PM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 06:42 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 01:12 PM
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 10:42 PM
