New Furnace Choice - HVAC - DIY Chatroom Home Improvement Forum
Old 03-15-2012, 07:08 AM   #1
Rewards Points: 121
New Furnace choice
This i know may not be easy and usually you get some liking certain models ..but is there one furnace here that does stand out better then the rest...
If i go to a new furnace, having a single stage installed now,, i am thinking of a dual stage furnace, as hydro here in Ontario is very costly, so i want to save electricity..here are 3 choices
Keeprite - Hi Eff. Gas Furnace - Two Stage - Variable Speed - DC Motor - 96% AFUE - Natural Gas - 80000 BTU - G9MXT080-IIX96 -
Ruud / Rheem - Hi Eff. Gas Furnace - Two Stage - Variable Speed - DC Motor - UP FLOW - 95% AFUE - Natural Gas - 75000 BTU - RGRM-07EYBGS -
Carrier Performance 96 - Hi Eff. Gas Furnace - Two Stage - Variable Speed - DC Motor - Up to 96.7% AFUE - Natural Gas - 80000 BTU Ė 59TP5A080 - $2480
rick31797 is offline   Reply With Quote
Old 03-15-2012, 08:50 AM   #2
All furnaces will perform well if installed properly.
Asking that question is like asking what is the the best car. Everybody has their favorite ...
hvac5646 is offline   Reply With Quote
Old 03-15-2012, 08:58 AM   #3
Rewards Points: 121
I thought i would get a reply like this...but HVAC installers have furnaces also, why are they picking one over another..its not because of installations..
Old 03-15-2012, 05:37 PM   #4
Rewards Points: 380
I installed a Carrier 3 stage in my house about 3 years ago. Really like it, it is extremely quiet most of the time, has caused zero problems, and the higher efficiency has saved a fair bit over the last 3 winters. That being said, I am a Carrier dealer, so that is the product I went with. It is a lot easier to sell something, if it's what you have in your own home.
I'm sure you would be happy with the 96%. I have installed many over the last few years and my customers seem to like them. Any of the models with the ECM motors will draw very little power. I checked one a couple weeks ago, on low fire it was drawing .74 amps, and on high it was 2.2 amps (your regular unit could draw 5 to 8 amps).
HVACDave is offline   Reply With Quote
Old 03-15-2012, 06:00 PM   #5
An old Tradesmen
Rewards Points: 8,176
Well. Start with a load calc to find out what size your really need. Then have your duct work checked to see if it can handle the air flow of the new furnace(new furnaces need to move more air per BTU then the old ones did).
Old 03-15-2012, 06:43 PM   #6
Rewards Points: 121
Good information, the current furnace i have is a Clare Brothers HE@ 90 %..I have had it for 16 yrs, no problems other then a gas valve, until the last couple weeks..Just weighing my options. When we installed this furnace had a so called pro come in and look at the size of Furnace we would need to heat a 2500 SQ ft house, i trusted the guy knew what he was doing, turned out he under-sized the furnace..It has an output of 65000 BTU..and we just had all new windows and doors installed so we really have cut down on heat loss..
But it would be nice to have a up to date furnace that does use alot less hydro..Hydro is a huge concern in Ontario..
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 05:01 PM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 06:42 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 01:12 PM
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 10:42 PM
