New Furnace Blows Cold Air - HVAC - DIY Chatroom Home Improvement Forum
Old 02-07-2009, 10:24 AM   #1
Question
New furnace blows cold air
Garrison gas forced air furnace. Company installed 4 days ago, said it would be better and more cost effective then fixing old one. Now it blows cold air, they came back and turned fan down air has a "hint" of warmth in it. Set it to 70 degrees and it will not shut off because it wont get to 70 in house. (Very small house I will add.) The tech guy sais it is normal for the high efficient unit. Iam not understanding it, the duct work doesnt even get warm, everything appears to be working fine, the vent pipe is to hot to touch, flame looks good etc... Any comments? Please give me your thoughts.
Scottkauff is offline   Reply With Quote
Old 02-07-2009, 10:50 AM   #2
JohnH1's Avatar
No matter what you should be able to reach set temp of 70 deg. Eather the unit may be to small (not likley) or they did not do a proper set up of the install. Check gas pressure, temp rise, Static pressure or combustion test. Again this is only a guess. If you have a tempature sensor/thermometer of some sort. you should check the return air temp and then the supply air temp. Then compair to the furnace tag temp rise it is probly in the area of 30 to 60 deg to see if you are running within recomendations.
JohnH1 is offline   Reply With Quote
Old 02-07-2009, 08:31 PM   #3
Is it a 80% or 90% efficient furnace. What temp is it in the house?
Also, you must understand that your old furnace probably threw 160*F air but lost a lot of usable heat up the chimney as waste.
New furnaces put more heat in the home but with about 130to 140*F air.
Try holding your hand over the register for a longer period of time and then see if it does not feel hotter.
While your at it how big is the house and do you have an electronic thermostat?
(got a feeling about this one)
hvaclover is offline   Reply With Quote
Old 02-08-2009, 11:12 AM   #4
check to see if there is a reset button .
metx is offline   Reply With Quote
Old 02-08-2009, 11:15 AM   #5
Where did you get that pearl of wisdom from?
Old 02-08-2009, 01:00 PM   #6
HvacWiz's Avatar
Rewards Points: 252
HvacWiz is offline   Reply With Quote
Old 02-08-2009, 01:42 PM   #7
An old Tradesmen
Rewards Points: 6,500
Did you have them come back again yet.
Look on the data plate.
It will have a min and max temp rise.
While they are there. Have them check that it is within that min and max range.
Let us know what they do, and say.
Old 02-09-2009, 12:47 AM   #8
OP looked like another troll and didn't come back.
Old 02-09-2009, 04:11 AM   #9
Here is a clue - what high efficiency furnace has a vent pipe that is too hot to touch? somebody is being funny. Also if everything is working fine then you have no problem.
The remotest possibly for a hot vent stack would be a complete blockage of heat exchanger air along with a few temp sensor failures - it was pointed out earlier to do a static pressure test.
hychesee is offline   Reply With Quote
Old 02-18-2009, 11:38 AM   #10
not a newbie
jmcqueen's Avatar
metx, reset switch? yeeeaaaahhhhh....he also might want to check the fill level on the flux capacitor while he's in there poking around.
jmcqueen is offline   Reply With Quote
Old 02-18-2009, 01:10 PM   #11
Like I said, OP was a troll
My furnace blows cold air all day Lucky Strike HVAC 72 02-03-2009 09:45 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
CARRIER 58RAV Furnace Blows Cold Air-No Heat sarosie HVAC 2 12-05-2007 01:00 AM
