New Furnace & Air Conditioning Units - HVAC - DIY Chatroom Home Improvement Forum
Old 06-14-2010, 09:20 AM   #1
New furnace & air conditioning units
Considering in replacing furnace and air conditioner with a 95% efficient units. Problems: there is no drain close to where the furnace is located. Being told two things: One need a plumber to run a line to the nearest drain (second floor bathroom) two an antifreeze unit? which way to go. Any info on previous or new possibilities?
mcips is offline   Reply With Quote
Old 06-14-2010, 11:30 AM   #2
An old Tradesmen
Rewards Points: 7,832
Where will the furnace be installed. In an attic, mech room in garage?
Old 06-15-2010, 10:10 PM   #3
Garage
Old 06-15-2010, 10:27 PM   #4
An old Tradesmen
Depending on your local codes. You may need a plumber to tap into your plumbing drain pipes. often. You can run it to the drain line of your kitchen sink.
May need a condensate pump even to pump it to there though.
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
are central air units compatible with any furnace? firsttimeowner HVAC 3 08-10-2009 08:15 AM
furnace and air conditioning package price MichaelV HVAC 3 12-02-2008 08:19 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
