New Furnace - HVAC - Page 8 - DIY Chatroom Home Improvement Forum
Old 11-20-2013, 07:42 AM   #106
Rewards Points: 80
Originally Posted by french_guy View Post
Well, I did change the HCR (code 240) and set it to 3
I noticed the furnace was running longer, but still kicks in quite often
For example this morning, the furnace turned OFF at 6:30 am exactly, and turned back ON 8 minutes later.....
Set point is 20'C (68'F)
When the furnace turned back ON at 6:38 am, temperature in the room was still at the set point
May be the smart response technology that was set on ON is the problem?
I've just turned it OFF to see how it affects the cycles .....
When I first got digital stats, it drove me crazy how often it seem to come on and off. But it appears that it is just this type of stat keeping a closer eye on things.
Having said that though, I also have some high ceilings and stairways that bleed off my heat in the winter and cause more cycling.
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 11-20-2013, 04:04 PM   #107
An old Tradesmen
Rewards Points: 7,814
Give it another day set at 3 and see if it gets a little better. It will always show the temp to be at set point, even though the temp might be 1/2 degree above or below.
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 05:01 PM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 06:42 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 01:12 PM
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 10:42 PM
