New Furnace - HVAC - Page 7 - DIY Chatroom Home Improvement Forum
Old 11-12-2013, 06:48 PM   #91
Rewards Points: 1,046
I did buy the RTH8580WF at Home Depot, and they even honored a 25% coupon from Harbor Freight. I got it for $118 tax included
But this stat is huge.........!!!!
I was wondering if it would make more sense to go with the 9580 which is much smaller, but $60 more expensive
Other than aesthetic aspects, what are the technical differences?
french_guy is offline   Reply With Quote
Old 11-12-2013, 07:09 PM   #92
AKA HVACTECHFW
Rewards Points: 1,208
Changeable color background...
outdoor temp is displayed (downloaded from the internet)
indoor humidity is displayed, I think
that is pretty much it....
http://wifithermostat.com/Products/
The 8580 is not that huge.... just think about as you age you might need those larger numbers!
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 11-12-2013, 07:24 PM   #93
Anyway, my wife saw it and said it was OK
And she also said that I should pick what seems best to me
So i guess I will stick with that one, and see how it works
After all, it's more than a gadget, so let's try to keep the price reasonable
Old 11-18-2013, 07:32 PM   #94
OK, new furnace with new thermostat are installed and running
I like to play with the wifi apps from my cell phone to control my furnace
Only one thing I noticed: I feel the furnace is cycling more often with the new thermostat (rth8580wf)....
But globally, I am happy
Old 11-18-2013, 07:41 PM   #95
An old Tradesmen
Rewards Points: 6,544
Set its CPH to 3 or less. And then stop playing with the temp settings. LOL
The Following 2 Users Say Thank You to beenthere For This Useful Post:
hvactech126 (11-18-2013), raylo32 (11-18-2013)
Old 11-18-2013, 07:53 PM   #96
What is the CPH?
And what is the code to access it?
Old 11-18-2013, 07:58 PM   #97
AKA HVACTECHFW
Please read the installation manual for your thermostat for the answer to your question.
IT IS WHAT IT IS
Old 11-18-2013, 08:04 PM   #98
An old Tradesmen
Cycles Per Hour.
System set up 0240 and 0250. For first and second stage heating.
Old 11-18-2013, 08:35 PM   #99
Well, I did since I set up my wifi, and also changed the unit from fahrenheit to celsius (I'm French, so...............)
But code 240 is HCR (Heating Cycle Rate) and is supposed to be 5 for a standard gas furnace
Should I still select 3 or less, knowing that 3 is for a high efficiency furnace (mine is 80% "only")?
How does it work exactly?
Old 11-18-2013, 08:40 PM   #100
raylo32's Avatar
Rewards Points: 1,240
You can probably also play with the temp differences from actual to set temp. IOW you can have it kick on when it gets 1 degree below the setpoint, 1.5 degrees below the setpoint, 2 degrees, etc. That will affect how often it runs. Not sure what the default is on the Honeywells....
Live long and prosper.
raylo32 is offline   Reply With Quote
Old 11-18-2013, 08:40 PM   #101
An old Tradesmen
Set it to 3. It does some calculations to determine when to turn on, and off.
Old 11-18-2013, 08:40 PM   #102
AKA HVACTECHFW
When set to 3 vs 5 it will have a longer run time but less cycles per hour. 3 seems to be the best all around setting regardless of the type of system. Most homeowners are pretty happy with a setting of 3. Changing it to 4 will not hurt anything at all, in fact you can even change it every day after getting a feel for it to see where you are most happy.
IT IS WHAT IT IS
Old 11-18-2013, 08:42 PM   #103
OK, i will try to set it at 3 and I will let you know
Old 11-20-2013, 06:56 AM   #104
Well, I did change the HCR (code 240) and set it to 3
I noticed the furnace was running longer, but still kicks in quite often
For example this morning, the furnace turned OFF at 6:30 am exactly, and turned back ON 8 minutes later.....
Set point is 20'C (68'F)
When the furnace turned back ON at 6:38 am, temperature in the room was still at the set point
May be the smart response technology that was set on ON is the problem?
I've just turned it OFF to see how it affects the cycles .....
Old 11-20-2013, 07:31 AM   #105
AKA HVACTECHFW
Seal the hole the wires come through behind the thermostat. You also need to quit messing with it and let it learn how your home heats.
IT IS WHAT IT IS
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 06:01 PM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 07:42 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 02:12 PM
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 11:42 PM
