New Furnace - HVAC - Page 6 - DIY Chatroom Home Improvement Forum
Old 11-08-2013, 10:54 AM   #76
Hvac Pro
yuri's Avatar
Rewards Points: 2,240
Originally Posted by HVAC1000 View Post
In my experience electricians get confused and stop progress when it comes to thermostat wires.
They keep wanting to staple it every3 feet or so
Some are good and others we just gotta call Sparky or Smokey depending on how bad the short is.
The Following User Says Thank You to yuri For This Useful Post:
HVAC1000 (11-08-2013)
Old 11-08-2013, 01:03 PM   #77
Rewards Points: 1,050
Originally Posted by yuri View Post
if it is stapled you are screwed and 99% of the time it is. if you can run the new wire then do so. leave about 3 feet of it hanging near the floor of the old furnace as the new one is lower than the old one and the board is low to the ground so you don't want him to be short on wire. use 18/5 LVT thermostat wire and you can buy it by the foot at HDepot. or a small roll.
I would hookup your new tstat to the old furnace ( leave extra wire) and all you need to do is find the C terminal on the board and connect it there or post a pic of the wiring inside and we can help you. the guy is not getting paid to mount and hookup or commission your new complex stat (takes time probably a 1/2 hr) and unless you negotiate a price for that will end up with a bad relationship or job.
U have 2 low voltage wires going to the outside AC. one goes to Y and the other has to go to C so connect it there.
I will see first if I can run a new cable. If I can, I will look into the old furnace to find the C terminal - If I can't find it or I'm not sure, I will post a picture
Worst case scenario: I cannot run a new cable ()....!!! Which wifi stat could run w/o this C wire?
french_guy is offline   Reply With Quote
Old 11-08-2013, 01:17 PM   #78
Hvac Pro
yuri's Avatar
there is ALWAYS a way to run new wire and my top notch electrician would run the wire thru a closet and remount it on a different wall if necessary or go under baseboards etc. an experienced electrician has ALL kinds of tricks to do that but they are expensive. if you can find another wall out of view of sunlight or drafts or heat or cold vents then it can be remounted. sounds like a lot of hassle to me for what is a toy IMO but hey I am an old school guy.
there are Honeywell wireless stats and I am not sure if they have a wifi wireless stat but check out their site. going to be expensive though and need an interface module. click products>residential> thermostats
https://customer.honeywell.com/en-US...spx?cat=HonECC
Old 11-08-2013, 02:08 PM   #79
Is it possible that my 30 years old furnace doesn't even have a C terminal?
Anyway, it's no big deal...As long as I can run a new cable with the 5 wires, I assume the new furnace will have that C terminal, right?
Old 11-08-2013, 02:14 PM   #80
Hvac Pro
yuri's Avatar
your old furnace may have the C wire/terminal on the transformer. as long as you hookup the C wire from the tstat to where the wire from the outdoor AC attaches to (NOT the one from Y which you would need to note the color of the wire Y from the tstat to which of the 2 it attaches to for the AC) the you are OK. post some pics and we can tell you as it is easy.
Old 11-08-2013, 03:55 PM   #81
AKA HVACTECHFW
Rewards Points: 1,208
If you can't run new wire just let us know. There are a few choices of wireless stats that get pricey as said, but it can be done. Here is another option: http://youtu.be/O64sF-jQ0eY
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 11-10-2013, 07:09 PM   #82
OK, I was able to run a new wire....that was easy actually. I didn't run the thermostat cable yet (18/5) but another piece of small wire that I will use to pull the new cable
And about the current furnace, here is a picture of the panel...... Looks like the blue wire is on the Y terminal (which matches with the cabling on the thermostat - 2nd picture)
There is a blue wire, but apparently it isn't the C since it is wired on the Y of the thermostat !!!
Let me know if I can wire a real C (blue) wire....and where
Old 11-10-2013, 07:28 PM   #83
An old Tradesmen
Rewards Points: 7,328
In the pic of the furnace board. See the 2 conductor wire. The red wire is on the C terminal. Thats the common. You can wires your thermostat's common to that terminal.
Old 11-10-2013, 07:36 PM   #84
So the Blue wire of the new cable should go on the circled terminal?
And the Yellow wire should go where the blue wire is currently installed?
The 3 others are OK (Green on GC, Red on R and White on W)?
Old 11-10-2013, 07:45 PM   #85
An old Tradesmen
Yes, that is correct.
Old 11-10-2013, 08:00 PM   #86
I know it was 30 years ago, but I wonder why they put the blue wire on the Y terminal?
Apparently, the cable is a 4 conductors, without any Yellow wire....that's weird, no?
Was it common at this time to use 4 wires cable with no yellow?
Old 11-10-2013, 08:07 PM   #87
An old Tradesmen
Not unusual.
Old 11-10-2013, 10:14 PM   #88
Hvac Pro
yuri's Avatar
blue is the HVAC color of cool/icicle and red is hot/flame. very rare that you get 4 wire with a yellow wire. all depends on the installer. I have seen guys use black for w, white for C which is Common and with 110 volts white is C or neutral and black is hot. all depends on the installer. the wire manufacturers don't make the wire just for HVAC but for alarm systems and anybody else that wants it and yellow is not that common with 4 wire.
Old 11-11-2013, 12:45 PM   #89
I didnít realize, but the RTH8580WF is kind of hugeÖÖWill have to get the WAF to buy and install it
Old 11-11-2013, 05:40 PM   #90
As for a new furnace--
Always get a furnace from a installer who you think/knows will get the job done right. A bad installation will make a good-rated furnace last a week, and a great installation can make a bad furnace last decades. They should also do a load calculation to make sure the new system is not too big/too small for your home. Too small or too big of furnace will cut down on the life expectancy of the system and make it run more inefficient. My tip to homeowners is to avoid the big chains like MasterTech, Brunner-Peters, etc. Try to go locally-owned and family owned, as they are usually (but not always) the people that give you the best service.
Just my 2 cents. If this is more a brand issue (strongly recommend to read and heed my warning above) than ICP makes a pretty solid unit IMHO (yes, the experienced techs and people that love Trane will tell me I'm wrong and that ICP makes a pretty bad unit, but I will beg to differ.) If you want something more high-end with a better communicating system than the Observer, try the Bryant Evolution system or Carrier Infinity. (BTW, ICP is Arcoaire, Comfortmaker, Day & Night, Heil, KeepRite, and Tempstar.)
ModelAFan is offline   Reply With Quote
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 05:01 PM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 06:42 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 01:12 PM
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 10:42 PM
