New Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 12-14-2011, 11:07 AM   #1
New furnace
Greetings,
I have a Weathermaker unit that has a failing secondary heat exchanger (Smelly CO laden exhaust) and the quote to replace the parts was outrageous so I've purchased a replacement unit. Yes, it is one of the units covered by the class action lawsuit, but the labor to install the replacement parts costs more than a new furnace and by just replacing it I wind up with a new unit vs. one that is 11 years old.
I have a couple of issues that I'd like to address while installing the replacement unit.
The installers that put the current unit in place did a very poor job on the supply side transition and there is direct sheet metal to sheet metal contact at the flexible boot which causes quite a bit of vibration on the floor above when the unit is running. Where does one go to purchase a replacement boot/transition sheet metal duct work? Should I just start calling local HVAC suppliers? Will they deal with a homeowner directly? Are these standard "off the shelf" parts or do they have to be custom fabricated?
The new unit is identical in all dimensions, however it is 5" shorter than my existing unit, which is actually OK because the original installers failed to install a proper filter box. The unit is configured as a updraft, so I'd like to address this issue as well and install a filter housing under the furnace on the return side, once again, where does one go to purchase such a device locally?
Current furnace is a Carrier Weathermaker 9200
Replacement unit just arrived and is a York Affinity YP9C120D20MP
Here is a photo of the current install:
I appreciate any feedback!
-Dan
Dan Scherer is offline   Reply With Quote
Old 12-14-2011, 01:01 PM   #2
raylo32's Avatar
Rewards Points: 1,244
These guys sell filter racks/boxes that might fit. You'd have to check the specs to be sure. The ones for 1 and 2" filters come in various lengths and widths but I think they are all the same height (~ 3 3/4"). They also make racks for 1" filters if you can't fit the big one... which might be the case since you need room to put in that flex transition.
As to the flex transition, I think you could go to a local sheet metal shop with measurements and they could probably fab one for you.
http://www.alpinehomeair.com/viewpro...ctID=453061567
http://www.alpinehomeair.com/viewpro...ctID=453058263
raylo32 is offline   Reply With Quote
Old 12-14-2011, 06:45 PM   #3
An old Tradesmen
Rewards Points: 6,582
Sheet metal/fabrication shop can make what you want.
Must be a really big house to need that big of a furnace.
Old 12-27-2011, 06:26 PM   #4
Thanks for the feedback guys, with the chaos of the holidays I just tracked down a local installer who did a great job getting the new unit fitted in place and setup with the proper filters, well worth the $350!
Sometimes I just need to slow down and realize when it is best to hire a pro
Old 12-27-2011, 06:35 PM   #5
Hvac Pro
yuri's Avatar
Rewards Points: 1,454
Sounds like a good price too.
Old 12-27-2011, 06:51 PM   #6
Originally Posted by Dan Scherer View Post
Greetings,
-Dan
Not much you can do about the bottom, perhaps take the unit back out and put a rubber gasket of some type all the way around, but the top is very do-able, what your looking for is called a canvas connector, very common used daily in hundreds of thousands of installs, why the hacks that did your unit did not use one, I would have to say they was doing it a cheap as humanly possible.
harleyrider is offline   Reply With Quote
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 06:01 PM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 07:42 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 02:12 PM
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 11:42 PM
