New Flue Liner Regulations-NY
Anybody have info about regulations on having to add a flue liner when converting from oil to gas? And when they went into effect?
Ron |
Hi Ron6519
I am not sure about NY, but this has been a mechanical code for most of the country since the advent of 80 plus furnaces. The reason being is the difference in flue temps, as the efficency went up the flue temps went down. This generates moisture that in turn creates a mild acid that deteriorates the mortar in the brick and allows flue gas leakage. You can get the liner kits at Johnstone Supply, Grainger or other reputable supply houses. However grab your bottle of nitro and keep focused, they are not cheap. Good luck Rusty |
I recommend FasNSeal products manufactured by Protech, Inc. I used to manufacture this stuff and it's excellent. They can help you design a system within NYS specs.
If you had an oil burner and a class A flue (not brick & morter) you don't need a flue liner. Not that when I converted from oil to gas the contractor didn't try to sell me one anyway...
I guess I'll have to drop a camera down there every year or so to keep track of the mortar. I would still like to know when the law changed and where I can read about it. I couldn't find it perusing State Building Code information. Ron |
Ron, I'm in Suffolk - if your chimney is on the exterior of your house and in good shape, I really wouldn't worry about it for a while. (Certianly not annually.) If it runs up the interior, you could always go with a liner.
| All times are GMT -4. The time now is 03:43 AM. |
