New Flame Sensor Not Working - HVAC - DIY Chatroom Home Improvement Forum
Old 10-21-2011, 03:51 PM   #1
New flame sensor not working
I just installed a new flame sensor/ignitor combo in my Heil SP80 furnace. It STILL WON"T DETECT A FLAME!!!!!!
At first, just after installation, the small gas line that provides the gas for a pilot light worked perfectly. The ignitor got bright red, then ignited the gas and the pilot light was lit. The flame sensor STILL didn't signal the controller to turn on the gas for the burners though.
Now, the pilot light gas won't turn on at all. I'm at the end of my rope here and really need some help.
Any advice???
tryintofixit is offline   Reply With Quote
Old 10-21-2011, 04:57 PM   #2
An old Tradesmen
Rewards Points: 6,086
Probably wasn't the sensor to begin with. Check connections at gas valve.
Old 10-22-2011, 09:52 PM   #3
Rewards Points: 582
heil and tempstar had a connection problem on the older units with smart valves where ignitor pluged on to valve check this connection.....you may need a new valve.....how old is unit again
Old 10-22-2011, 10:14 PM   #4
I'm Your Huckleberry
Rewards Points: 2,270
Flame sensors work by sensing the passing electrical signal through the flame, tested in micro amps.
You need a good ground (wire) for this to work. Check all connections, making certain of course that the main power to the unit has a ground wire and that it and all grounds (as well as neutrals) are connected properly.
Doc Holliday is offline   Reply With Quote
Old 10-23-2011, 04:03 AM   #5
AKA HVACTECHFW
Rewards Points: 1,208
SMART (dumb) VALVE problem!!!
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
York Diamond 80 Intermitten Flame Setdyi HVAC 38 02-08-2014 01:20 PM
Carrier furnace flame rollout keeps tripping - why? Billyv HVAC 29 10-24-2011 09:48 PM
Maytag IntelliDry pye/4500 Dryer not working 57_Hemi Electrical 2 11-19-2010 10:28 PM
flame sensor problem junkcollector HVAC 1 12-09-2009 09:19 AM
Two switch in one box: only one working jdtsmith Electrical 12 09-29-2008 02:32 PM
