New Fan Motor Cutting In And Out. - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-21-2012, 10:09 PM   #16
An old Tradesmen
Rewards Points: 6,870
Yes. the white wire, and the brown with white stripe have the same connection point inside the motor. So it can be capped off when the motor is used as a 3 wire connection.
Old 05-21-2012, 10:14 PM   #17
So I guess I have some other kind of issue. It seems it is all wired right. I dont know what to try next. It just keeps starting and stopping over and over. It doesnt even seem like the compressor is kicking on either.
markyb123 is offline   Reply With Quote
Old 05-21-2012, 10:20 PM   #18
Should the black be hooked to the T1 or T2 terminal or doesnt it matter?
Old 05-21-2012, 10:21 PM   #19
An old Tradesmen
Why did you get a new motor? Was the old one doing the same?
Old 05-21-2012, 10:24 PM   #20
Old one was froze up. Fan would not turn.
Old 05-21-2012, 10:25 PM   #21
Rewards Points: 616
I suspect wiring issues.... very odd a new motor will not work...... it does happen though
carmon is offline   Reply With Quote
Old 05-21-2012, 10:26 PM   #22
An old Tradesmen
Are you sure you don't have the black wire too far under the terminal screw. And have the insulation in it.
Old 05-21-2012, 10:28 PM   #23
There is no srew, it is a flat prong connection like what is on the Cap. I had it on the t2 side though, I am trying it on the t1 side to see if that works.
