Old 05-25-2009, 04:58 PM   #1
New Electric Convection Heating Panels--Any Experience?
I'm impressed with the stats on the new technology in electric convection heating panels (Econo Heat). They use only 260 or 400 watts are about 18 inches square and are about 1 inch thick. Evidently they have been in use in Europe for some time but are new in North America. Anyone have any experience with these, good or bad? I'm looking to replace oil heating in our 1200 sq ft rancher and like the idea that, unlike conventional electric baseboard heaters, I wont have to upgrade our electrical service to accommodate these heaters and they are very affordable. Links below to two companies. Any thoughts? thanks.
US: http://www.eheat.com/site/products.php
Canada: https://www.econo-heat.ca/faq.html
akimbo is offline   Reply With Quote
Old 05-25-2009, 06:03 PM   #2
It was a dark and stormy
Yoyizit's Avatar
How much for oil and elec. in your area?
1 Therm of energy can be had from approx. 0.71 gal of fuel oil, 29 kwh of elec heat or 8.4 kwh of heat pump heat.
Old 05-25-2009, 06:32 PM   #3
Oil is $1.05/Liter or $4.00 a gallon. Electricity is 5 cents per kW.h. This past winter our oil costs were about $3,000 or 430/mo from October to April and our electricity was about $120/mo (that's with a few electric space heaters plugged in). Electricity is relatively cheap here (British Columbia).
We just purchased this house last September and it's the first time we've had oil heat. We were shocked at the cost. We tripled the attic insulation and may also upgrade the windows which I know will help, but the cost is about 10,000 for the windows. These heat panels only cost about $94 each, delivered--much cheaper than baseboards and, according to them, much more efficient, and better at circulating air throughout the room. We thought it might a be a cheap way to add a supplementary heating system to the house for only about $1100 plus the cost of thermostats and installation. You can easily install them yourself but it would be nice to have wall-mounted thermostats so we expect to have some electrician costs. But, there isn't much info out there about people's experience. If it's too good to be true . . . still, I believe we are well overdue to more efficient heating technology, and this may very well be a step in the right direction.
Old 05-25-2009, 08:47 PM   #4
An old Tradesmen
A conventional electric baseboard heater that uses 400watts(about the size used in a bathroom). Will provide 1,365 BTUs of heat.
One of those Econo heat panels that uses 400 watts will provide 1,365 BTUs of heat.
They just look nicer.
Old 05-25-2009, 09:12 PM   #5
Yoyizit's Avatar
Month starting HDD
10/1/08 682
11/1/08 826
12/1/08 1301
1/1/09 1170
2/1/09 1000
3/1/09 1054
4/1/09 735
So 750 gals of oil giving 1100 therms for 6800 HDD for 180 days for 1200 sq. ft.
6.1 therms/day
1200 sq. ft gives 6.1/1200 = 509 BTU/day/sq.ft.
6800/180 = 38 HDD in one day
509/38 = 13 BTU/day/sq. ft./HDD
That is, if you're in Whistler.
For a house in DC,
838 therms of NG in 90 days = 9.3 therms/day
3100 sq. ft. including basement gives 9.3/3100 = 300 BTU/day/sq.ft.
2658 HDD/90 = 30 HDD in one day
300/30 = 10 BTU/day/sq.ft./HDD
Old 05-25-2009, 09:31 PM   #6
An old Tradesmen
13*1200=15,600*65=1,014,000/140,000=7.2428
So on a 65HDD day. He used 7.24 gallons of oil?
Old 05-25-2009, 09:34 PM   #7
Yoyizit's Avatar
You know I can't do math!
Well, he did use 750 gals in 180 days = 4.2 gals/day for the avg. 38 HDD for each day.
4.2(65/38) = 7.2.
If there is a mistake it must be farther upstream. Maybe he lives in a warmer or colder place than Whistler.
http://www.degreedays.net/
Old 05-25-2009, 10:22 PM   #8
The bathroom size Econo is 260 watts. The 400 watt size will heat a 10 x 10 room. So I'm comparing what I think will be a 1500 Watt baseboard heater for a bedroom to a 400 watt Econo panel.
Old 05-25-2009, 10:33 PM   #9
4.2(65/38) = 7.2.
Sorry. The entire house is 2000 sq ft, however the basement suite doesn't get much of the air flow from the oil heater. They relied more on space heaters. The house is in Victoria which is a warmer place than Whistler, but it was a cold winter this year. It's Zone A: <= 3500 HDDs, the mildest zone in Canada--that's why we bought there
Old 05-25-2009, 10:33 PM   #10
An old Tradesmen
When I said the size for a bathroom. I was refering to a standard/conventional electric baseboard heater. They are anywhere from 250 to 500 watts.
I wouldn't believe them 100% about a 400 watt heating a 10x10 room.(Same amount of heat as 4-100 watt light bulbs)
If that was true. Then if you got 12 of the 400 watt ones. You could heat your whole house with 4,800 watts. Or, 16,382 BTUs.
It will probably heat a 10x10 room at some temps, but don't bet on it being ablet to do so at your coldest winter temps.
Old 05-25-2009, 10:54 PM   #11
... I wouldn't believe them 100% about a 400 watt heating a 10x10 room.(Same amount of heat as 4-100 watt light bulbs)
Yes, in fact I've read some user criticisms saying that on really cold days they were inadequate, but they were reporting from colder climates. Plus I would hope that a 400 watt convection heater would have better circulating efficiency than 4 light bulbs.
Old 05-25-2009, 11:09 PM   #12
An old Tradesmen
Actually, 4 light bulbs of the proper type, would heat better.
Remember, convection means it heats the air.
Which is ok.
A light bulb heats objects by radiant heat, which means you feel warmer. Without creating cool air currents.
Heaters like that, are great for adding additional heat. To rooms that are hard to heat.
Or for rooms/areas that you don't heat all the time. And keep the registers closed when not using them. And don't want to have to turn up the stat, and heat the whole house. Just to heat that room/area for an hour.
Old 05-25-2009, 11:31 PM   #13
So, do you feel the same way about convection heaters, such as http://www.convectair.ca/caen/produi...gro.html#fiche. Our electrician is not familiar with the Econo Heat, but he has the Convectair and loves them; so does our contractor, but they are about $500 each. Think a 500 watt one would be no different than 5 light bulbs, or no different than a standard electric baseboard?
Old 05-25-2009, 11:39 PM   #14
An old Tradesmen
Its just a pretty package.
For every watt consumed, you'll get 3.413BTUs of heat. The same as a conventional electric baseboard heater.
Those are probably never going to give you a crackling sound like a regular baseboard can when it gets old.
but, it wil cost the same, for the same amount of heat.
Old 05-26-2009, 12:54 PM   #15
Yoyizit's Avatar
For heat loss, your house is at d
.... .a..b..c.d
0....5.....10.....15..
out of a sample of four houses in North America.
Slate Floor Electric Underfloor Heating Lottie Flooring 6 03-19-2011 02:50 PM
Electrical consumption of baseboard heater CowboyAndy Electrical 7 03-24-2008 08:27 PM
forced air on first floor, electric heating on 2nd? BleachCola HVAC 6 01-06-2008 09:43 AM
