New Ductwork Question - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-24-2013, 08:11 AM   #16
Rewards Points: 160
Originally Posted by beenthere View Post
They can all stay 7" then.
if you say i can keep them at 7in are my current trunks too small at 9.5in by 8in? if not couldnt i just get a duct cleaning and save some money? i think it looks too small but im not the expert. i kind of want to upgrade and get new ones but im sure cleaning them would have to help air flow too because they are really dirty
also the bathroom ones are located above the furnance so those runs are real small and they get alot of air coming out harder of the register than the rooms. maybe a smaller duct wouldnt be the worst idea for those to try and push air in other directions
jhack836 is offline   Reply With Quote
Old 03-24-2013, 08:15 AM   #17
An old Tradesmen
Rewards Points: 8,236
Your trunks are too small.
Air blows out of some of the registers pretty hard, doesn't it.
Old 03-24-2013, 09:35 AM   #18
Rewards Points: 160
yup ha, thats what i figured and got me started on this project in the 1st place, its more noticable in the summer with the ac on, you can feel the difference walking down the hallway
Old 03-24-2013, 09:38 AM   #19
Rewards Points: 160
can i keep them all at 7in but change the bathrooms to 4in? i would like to get the most air to kitchen and living room as possible because that is the area that feels warmer in the summer or would that affect your calculations you did for me?
Old 03-24-2013, 11:22 AM   #20
An old Tradesmen
You can make the bathrooms 4". The under sized trunk lines you have are causing most of your air problems. What size is your A/C.
Old 03-24-2013, 12:17 PM   #21
Rewards Points: 160
i forgot to check, i will go check, hope i can find the info, it is a older one i think, it came with the house when we bought it a yr and half ago.
Old 03-24-2013, 12:59 PM   #22
Rewards Points: 160
i had to do a little research since they discontinued mine. it is a Payne PA10JA024-A ( do you know what the A means because i found mostly that model number with a C at the end)
it was installed in July 2001 as the serial number is 2601E10921. According to the model number that ends with a C it is 10 SEEK and 22000 BTU so i believe that is just under 2 ton?? personally i always thought it was too small for my house but like i said im not an expert in HVAC
Old 03-24-2013, 01:15 PM   #23
An old Tradesmen
Its a 2 ton unit. The c should just be a revision indicator.
With better air flow it should cool the house better.
Old 03-24-2013, 01:29 PM   #24
Rewards Points: 160
Mine is a A though? what does that mean
Old 03-24-2013, 02:39 PM   #25
An old Tradesmen
Revision A. Or the first of its line of models. its meaningless to us. but means something to them. All manufacturers has revision designations.
Old 03-24-2013, 03:07 PM   #26
Rewards Points: 160
oh ok thanks, do you think my ac is too small or will it be fine with new ducts?
Old 03-24-2013, 03:11 PM   #27
An old Tradesmen
Probably be fine with new duct work for better air flow.
Old 03-24-2013, 03:14 PM   #28
Rewards Points: 160
since my basement is not finished but you recomended running a trunk for it would that affect the rest of the house until i finish it because i dont really need the basement to have same temps right now since it is not a living area.
Old 03-24-2013, 03:23 PM   #29
An old Tradesmen
Put a manual damper in the trunk line for the basement so it only partially heats the basement.
Old 03-24-2013, 04:32 PM   #30
Rewards Points: 160
thanks for you help!! i was just looking on menards.com does it matter what gauge? just standard for the pipers and the 28 guage for the trunks?
Basement framing - drywall ceiling question tmhouse Building & Construction 1 07-11-2011 12:11 PM
Branching ductwork from a wall stack cekrauss HVAC 3 07-08-2011 04:00 AM
Ductwork on a SOUTH DAKOTA remodel asorenso General DIY Discussions 1 02-11-2009 05:55 AM
Ductwork question veesubotee HVAC 4 01-27-2009 08:24 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
