New Ductwork In Attic- Cost? - HVAC - DIY Chatroom Home Improvement Forum
Old 06-20-2011, 02:35 PM   #1
New Ductwork in Attic- cost?
Hi,
I live in a ranch condo, about 1200 SF. I have a full attic with easy access. Currently, my heat and AC run through my concrete slab. The air is cold in the winter by the time it gets to the outer rooms. I tried to have the ducts cleaned due to some serious allergy irritations and I was told it can't be done well because of poor access to the actual clay pipes the air is going through.
I live in Ohio. I want to have new duct work ran through my attic and currently I have 6 vents.
Any idea of general cost here?
I am at a loss and I don't know if this is the best solution.
ishie913 is offline   Reply With Quote
Old 06-20-2011, 02:46 PM   #2
Rewards Points: 6,652
There is actually a sister site to this one http://www.hvacsite.com/ that may be able to better answer. As for the number of vents, it is easier to have at least a minimum of three bids on something like this, than trying to get an answer on the web. As for the old duct work, you would have to find out if the contractor would take care of closing up those openings once the old equipment is removed, and would they also sub out having a drywall contractor come in to repair where they have to cut into the walls to place the cold air returns, or in the case that they may have to place heating ducts on the walls, vs in the ceiling to help better distribute the heated & conditioned air.
The Following User Says Thank You to gregzoll For This Useful Post:
ishie913 (06-20-2011)
Old 06-20-2011, 02:52 PM   #3
Thanks.
I do have 2 estimates set up....I just don't want to be completely caught off guard when I hear a number. I am a little apprehensive because the guy who normally works on my furnace won't even do an estimate for this.
Old 06-20-2011, 07:42 PM   #4
An old Tradesmen
Rewards Points: 6,098
that is a pro only site. And does not answer home owner questions of any type.
Only contractors in your area can give a price on the work yo u want done. So call several.
Air sealing, ventilation, and attic insulation project-need advice Badfish740 General DIY Discussions 4 06-01-2011 07:48 AM
Ventilating attic with two roofs senorbungle Building & Construction 2 01-09-2011 05:17 PM
Insulation, Ventilation in Cape Cod Side Attic Get'n er done Building & Construction 10 12-03-2010 12:38 AM
Excess moisture/condensation/frost in attic Fingers General DIY Discussions 2 12-29-2009 11:38 PM
Attic moisture Carstonio Roofing/Siding 14 01-29-2009 12:35 PM
