New Duct Supply Runs For Basement Finishing Project - HVAC - DIY Chatroom Home Improvement Forum
Old 07-08-2013, 11:24 PM   #1
Rewards Points: 109
New Duct supply runs for basement finishing project
Hello,
Sorry for the long post, but want to try and include as much info as I can.
I am in the process of finishing my basement. I had a few questions with regards to installing a few supply lines for the basement. Currently, my trunk is 10"x20" wide for most of the basement, and then about 3/4th of the way down the line, the trunk reduces to 8"x14" wide. I believe I have a 3.5 ton or 4 ton furnace, main levels of house is about 2300 sf. The furnace sits on the east side of my house, and the trunk runs pretty much across the full length of the basement to the west. Through out the length of the trunk there are numerous 6" diameter supply lines which branch off the top to deliver air to the rest of the house. On the underside of the trunk, there are two openings for vents (see photo). One is about 1/4th of the way down, on the 10x20 size trunk section, the other is near the end of the main trunk, in the 8x14 section of trunk, (you can see first vent at top right corner of picture, other vent opening is towards end of line, hard to see).
I live in Chicago area, so hot summers, cold winters. I have insulated the foundation walls with XPS foam board, and will also install fiberlgass in stud wall (will have total of about R-23 for walls). Subfloor is also insulated, temperature is already much nicer compared to before insulation was installed. I am not sure how much air I will actually need to keep the temperature nice, I figured the air lines would be more for to keep the air moving, rather than having stationary/stale air, which is what I always thought led to having the musty smell in basements (am I incorrect on this?). I will most likely also be adding a dehumidifier.
The finished square footage of basement will be about 800 sf. I dont want to add too many lines, and take away from the air flow to the rest of the house.
My questions were as follows:
1) How many extra lines do you think I need ( I was thinking 2 lines, on top of the existing 2 vents on the bottom of the main trunk line).
2) What size vent lines can I use, do I need to use 6" diameter lines, or can I use smaller, like 3" or 4" diameter lines?
3) Do I need to install return line, and tap into existing return? (Was most likely going to do this, but just want to verify). If needed, then what size line? Only have a 2x4 stud wall for the return line, so cant go more than 3" diameter, unless use box shape. Was going to install the return near the floor.
4) I was going to install the lines between joists, and then have the vent come out of the drop ceiling, or would it be better to have the vent come out of the wall, near the top of the wall, close to the drop ceiling?
Let me know if there are any other questions you need me to answer, or any other info you need me to provide. I can also provide pictures of the area if needed.
Thanks in advance,
Steve
svaic00 is offline   Reply With Quote
Old 07-09-2013, 12:10 PM   #2
^ following
D3ZINER is offline   Reply With Quote
Old 07-09-2013, 10:09 PM   #3
Rewards Points: 446
Stick with 6" lines simply because it will make it much easier to buy the material.
Return needed? Absolutely.
How many supplies and returns should be determined by doing a heat load calculation on the space to figure out the CFM of air needed to supply the needed Btu's. There are online programs to do this with yourself.
If you want to proceed without this information you do/will have the benefit of having a dropped ceiling which would allow you to modify if necessary.
old_squid is offline   Reply With Quote
Old 07-09-2013, 10:48 PM   #4
Experienced HVAC Tech
HVAC1000's Avatar
Yes I always use the rectangular "wall stack" for the returns near the floor. It comes in sizes of 3 1/4X10, 12, 14, and 16 and fit nicely in a wall cavity. You can even put two side by side and have a 6X36" return grill
HVAC1000 is offline   Reply With Quote
Old 07-10-2013, 04:40 AM   #5
An old Tradesmen
Rewards Points: 7,332
Is it going to be 1 large open space. Or multiple rooms with closeable doors.
Old 07-10-2013, 01:34 PM   #6
Rewards Points: 109
One large open room
Old 07-10-2013, 04:58 PM   #7
An old Tradesmen
In reality. As far as conditioning the room goes then, you would be better off with a mini split. Or zoning the system. A bit expensive either way.
What often happens in the late spring and early fall. is the first floor is warmed by the sun, and the thermostat doesn't call for heat. The coolest air from that floor drops into the basement and keeps it feeling a bit too cool. Then when the A/C runs in the summer, it tends to over cool the basement since there is very little heat gain in it.
Ceiling penetration - supply duct lakeresident HVAC 3 05-18-2013 08:47 AM
Planning on New duct work..any feedback... kilosos2 HVAC 28 01-26-2011 09:21 AM
My basement finishing project DIY4EVER Project Showcase 6 02-18-2008 08:21 PM
Wiring Project - Need opinions boyfly Electrical 13 02-01-2008 03:52 PM
A newbie basement finishing project DIY4EVER Building & Construction 6 05-11-2007 09:48 AM
